Old 06-22-2021, 06:28 PM   #1
Best Way to Fill the Emergency Exit
Hello Fellow Skoolies, I'm working on a fiberglass 15 passenger shuttle bus and was wondering what this group thought would be the best way to fill the opening where the roof emergency exit was removed. The opening is 29" X 29". I'm considering a polycarbonate sheet like Lexan, aluminum sheet, fiberglass sheet or making my own poor man's fiberglass panel. In the future I'll be using the opening to install a roof mount RV air conditioner. Of course, I'd like a soluition that will last many years (5-10, if possible). All these choices except the poor man's fiberglass seem fairly expensive. What do you think would be the best material to use? Thanks for any input you might have.
--Chris
chrishowl is offline   Reply With Quote
Old 06-22-2021, 06:33 PM   #2
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
The best way would be to keep the emergency exit ...
ABBus is offline   Reply With Quote
Old 06-29-2021, 07:21 AM   #3
One way would be to remove the exit and to put a metal panel on the roof with a sealant under it and screw, pop rivet it down. Or weld it in place ( a better option) then when your ready ( if ever) to add the AC, put it in a different place.
zen builder is offline   Reply With Quote
Old 06-29-2021, 08:33 AM   #4
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
(https://www.skoolie.net/forums/membe...hes-page2.html)
You can rivet a steel (or AL) patch through the fiberglass. Maybe one with the standard 14" sq (14-3/16") hole, so you can swap out any rv accessory you choose.
Use a backer strip or washers on the inside so the fiberglass is squeezed between. Optionally, you may use epoxy on each rivet as you set them. Same on the backer strip.
A wide overlap will add rigidity to the assembly.
Many light aircraft manufacturers rivet fiberglass cowling nose bowls, fiberglass landing light mounts to AL, piano hinges to fiberglass... often using rivets and washers or backer plate.
Old 09-02-2021, 02:47 PM   #5
How I solved the problem
A quick note to let folks know how I filled the roof emergency exit. I put a sheet of plywood underneath and bought a piece of thick aluminum and screwed that in then sealed it up.
So now it's ready for my roof mount RV air conditioner installation.
Old 09-02-2021, 03:01 PM   #6
I put some plywood underneath first. Then I installed a sheet of aluminum to fill the emergency exit. Now it's ready for A/C installation.
Old 09-02-2021, 03:34 PM   #7
Lexan gives the advantage to more light in the house. I did Lexan in both, front and rear hatches, and added a fan/vent in the rear one. There was a 10" passive vent in the front that also got a Lexan window.
Old 09-02-2021, 05:07 PM   #8
Best way to do it, IMO.
emergency hatch, fill opening, shuttle bus conversion
