RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-04-2017, 05:40 PM   #341
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
Kitchen.
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 09-04-2017, 05:51 PM   #342
Getting the rear leaf springs redone, they are flat if not negative, One leaf spring weighs 130 pounds on the scale, i found a place about 1 hour away that will custom make or re-arch existing springs. I am going to keep the first 5, & delete the last 6, with the installation of the air bags i have, cant wait to feel the ride after.
Blue Sky's
Old 09-04-2017, 09:50 PM   #343
When its not 110 outside.
Blue Sky's
Old 09-08-2017, 10:26 AM   #344
Stove cubby.
Blue Sky's
Old 09-08-2017, 10:47 AM   #345
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Looks great- no squeaks with that welded frame.
What stove are you going with?
Old 09-08-2017, 05:31 PM   #346
stove is a coleman 2 burner classic. pull it out set it on top & burn.
Old 09-08-2017, 05:48 PM   #347
Nice welded frame!! Love the simplicity of grab the coleman, cook dinner, cool it and shove it back away again!
Old 09-09-2017, 01:07 AM   #348
You bet; cook inside or out.! Simplicity is as simplicity does.!! I may not be a very smart man, but i know how to bug the hell out of my neighbors with a chop saw & grinder everyday.
Blue Sky's
Old 09-09-2017, 10:21 AM   #349
joeblack5's Avatar
Year: 98
What airbags are you going to use? I am doing the same on Elfie. I think about the 3800lbs ones . not so much for the weight but they are supposed to give a softer ride with low pressure.
Later j
Old 09-10-2017, 12:43 AM   #350
joeblack5- I have the hellwig e350/cub wagon van. rated for 5000 pounds. I was going to install them last weekend but you know.!! work gets in the way.
Blue Sky's
Old 09-10-2017, 05:21 AM   #351
other than lawsuit, one can have custom lic plate made n place it above the legal one, or maybe one on each side... just to screw with them
Old 09-10-2017, 08:28 AM   #352
joeblack5's Avatar
Year: 98
Work, a couple of kids and old houses will do that for you,
Looked up the helwigs.... It looks like these are installed inside the frame?
Mine, I found on the junkyard, the brackets looked pretty heavy duty, they came of a dually mounted on the outside of the frame. I have a single rear wheel so I will be installing on the outside.
Inside would be nice as well, it would give me a little more articulation that i would like after I have Elfie converted to 4x4.
Later J
Old 09-10-2017, 12:06 PM   #353
chev49-i could but it just wouldent be the same as a government issued plate, that will be last resort if i dont get a custom plate i will be happy with.
joeblack5-no kids for me , i traded them for flying.
My airbags sit directly under the frame & the brackets do attach to the inner frame & to top of air bag bracket. Im ready for a new rear end i put of with it as long as possible. Cant wait to see were you take that 4x4..
My waste water take finally came in fits perfectly.
Blue Sky's
Old 09-10-2017, 10:26 PM   #354
Almost done.
Stove has nubs on bottom, helps keep it in place while in storage.
Strap on action.
Need to put some of that fabric they put on speaker boxes on the drawer, should be good.
Blue Sky's
Old 09-10-2017, 11:58 PM   #355
Better off with a solid surface than the carpet for under the stove. Absorbs ALL and will become a sticky mess over time.
Oldcarnut is offline   Reply With Quote
Old 09-11-2017, 01:09 AM   #356
oldcarnut- you are right ill add some a non-pores rubber mat.
Blue Sky's
Old 09-12-2017, 10:39 AM   #357
While i was at work dad finished my cabinets.
Blue Sky's
Old 09-12-2017, 10:45 AM   #358
Traveling
Rated Cap: '00
Nice ! Sliders are space-friendly.
Dad ROCKS !
Old 09-12-2017, 10:52 AM   #359
Those cabinets are trick !!!!! Nice work !!
Christopher
Old 09-15-2017, 09:37 PM   #360
Thanks, dad does. it is the one thing this whole project my dad didnt disagree with me on. Sliders seemed like the only real way to go.
Blue Sky's
