Should I change my bus name to Cannabus & paint it army green & black instead.? Im debating.
My ride is starting to look more like more motorhome less bus more home, I lost track of how much money I put into it all ready, I just don't even want to think about it anymore. I just started to leak oil, so I am little frustrated since in order to change the oil pan gasket you have to lift the entire motor, o'well just one more thing on the list.
My interior design. you want it.? since my dad would kill me if I downloaded CAD on his computer you will just need to use your imagination.
The side walls will get finished with insulation inside obviously, than black diamond plate along the side panels just under the windows the full length of the bus for the finish look.
The roof will get liquid rubber coating, insulation than bendable ply wood like what skateboard ramps are made of followed by black diamond plate aluminum sheet (.025 thickness ) to give the finish look of the roof.
The Floor will get liquid rubber coating, followed by a membrane than thin plywood with a dark cherry red finish wood, such as this.
The layout will look something like this.
The counter top will be black diamond plate with red sink. The table may be black diamond plate im still debating on that but to get an idea of what the inside is going to look like, similar to this but black diamond plate.
red and Black diamond plate is the color theme for the inside.
my dresser will look like this but red and black like the previous pic.
As far a a bed goes im still playing with the idea of using a truck cargo net that hangs from the first two pilliars and the last two pillars from the ceiling, & I will be sleeping above my counter, sink table and everything close to the roof but its not a for sure thin, every night I will pull it out of a corner attach the hooks pull tension and throw my small air mattress up and good to go. I hope I explained it well enough to get the idea.
