06-06-2017, 07:22 PM
#481
Started up the diesel mower today. Started real easy once I figured out how to turn the fuel petcock on.
Mows REAL nice!!!
06-06-2017, 08:16 PM
#482
In this area most of that government equipment, like mowers and tractors, are sold off with plugged up fuel filters or simple leaking fuel hoses.
Robin
Nobody's Business
06-06-2017, 08:18 PM
#483
The guards and inmates didn't like the push mowers, so these were BARELY USED!
I'd say they definitely had less than 500 hours on em.
I've never messed with a single cylinder diesel. This little thing is SO COOL! When mowing, it smells like a school bus.
06-06-2017, 10:28 PM
#484
Engine: 8.3 Cummins ISC
Rated Cap: 75
https://publicsurplus.com/sms/list/current?orgid=309249
That district in WV is listing two of those T444 shorties with the Spicer manual transmissions again. At least they added some more photos this time around. Seems like they're similiar in length to your bus. The 1998 and the two 1999 buses must've sold at the last auction.
06-07-2017, 05:02 AM
#485
At this point I'll have to pass on these. I've bid on them for at LEAST a year. They top out at 55mph, too.
06-07-2017, 07:13 AM
#486
im not sure where they came from but I passed 4 shorties in a caravan northward in kentucky last night.. 2 bluebirds like mine only 7 window. and 2 that looked just like EC's. 2 of them were T-444E's, and 2 had unmarked hoods.. not sure what those wouldve been.. seems not so many shorties on auction lately so not sure where they came from.. i did note I BLEW by them in my Silverado so they were only going like 55 or so..
EC - on that mower is it a PITA to pull the cord with a diesel engine? or is it one of those where you spring load the starter with the pull and then release it to actually spin?
06-07-2017, 10:24 AM
#487
Its not hard to start it, but I pull start stuff ALL DAY.
You just push the decompression lever and pull the cord. 1-2 pulls and its ALIVE!
Saw some buses heading down 75 from GA. They were headed to a used car lot in Lakeland.
06-07-2017, 11:11 AM
#488
so it has a lever that decompresses the cylinder until you get it spinning?
06-07-2017, 11:21 AM
#489
Yeah, you pull the cord just a tad till its a compression stroke, push down the decomp lever, and then pull start it.
So simple, powerful, and efficient!
06-09-2017, 02:34 PM
#490
WC Door
I don't recall where you are on your w/c door, but I did get over to a place that I passed on Interstate 10, East of Houston. They told me that they did deal in parts, as well as busses, and gave me a business card. Their site is
usedschoolbusesonline.com Phone # 855-607-6559
Also went by interstatebus@gmail.com AND interstatebusrentals.com
They weren't too chatty, with me, but I mentioned you had a AmTram and might need a w/c door. They needed the size, which I didn't know, so they said to check the website.
Good luck
06-09-2017, 05:43 PM
#491
ive noticed some newer IC busses that what looks like the exact same wheelchair door.. wonder if getting the VIN on a newer bus would help,
Paul's equiupment in ohio sometimes has quite a few scrapped out school busses..
06-09-2017, 11:21 PM
#492
Good luck
Thanks I'll try them monday. I REALLY NEED THAT WC DOOR SEAL!
06-09-2017, 11:23 PM
#493
Thanks! ANY leads appreciated.
I've tried looking on the web for IC, AmTran, Ward, and had no luck. I hate calling places. IDK why but I just do. Guess I need to make more calls. I'm getting to that point of NEEDING these few parts and its holding me up a bit.
06-10-2017, 07:24 AM
#494
06-10-2017, 08:00 AM
#495
wow what a pain that is.. looks like that back window mustve leaked for awhile.. my carpenter bus the back windows are sloped just a little and water always runs down along those windows... not sure why they built busses that way but ive seen a lot..
06-10-2017, 08:04 AM
#496
Yup, you're correct. It was the back window leaking, as well as the tail light.
The fiberglass that came out was MOLDY too.
06-10-2017, 11:48 AM
#497
You may check to see if you can get a complete door, with seal. Not the cheapest way, but might be 'the way'
06-10-2017, 02:30 PM
#498
IDK where I'd find that.
The few I've found online don't have the seal the door is hundreds and hundreds of dollars.
06-10-2017, 05:22 PM
#499
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
That's some NASTY cancer there.
06-10-2017, 09:48 PM
#500
Everything in that rear wall under the window that wasn't galvanized rusted completely away. GONE!
The rest of the bus is virtually rust free. only the WC door and service door have any real rust otherwise.
