RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-22-2021, 12:35 PM   #1
Floor questions
Iím a little lost on how I should prep my wood for installation. Iím going to pick up this wood to lay down on top of my insulation https://www.lowes.com/pd/Plytanium-2...-4-x-8/3602906
Itís untreated, am I supposed to use a wood sealant on it to protect the wood? If so, do I seal both sides? Or is this unnecessary and I can just screw the wood down? Any help is appreciated, Iím clueless
Piper is offline   Reply With Quote
Old 02-22-2021, 12:47 PM   #2
I wouldn’t spend the time or money to seal the subfloor.
Old 02-22-2021, 01:13 PM   #3
I'd just screw it down untreated, but in the grand scheme it wouldn't cost much to put a coat of Drylok on it just in case there's a water leak. If it was OSB I'd definitely recommend sealing it but plywood should be good to go.
Old 02-22-2021, 04:06 PM   #4
You could seal the joints in case of spilled water.
Old 02-22-2021, 05:57 PM   #5
I think you can put it in as is with no worries. Since it will be sitting on top of your insulation, it shouldn't get soaked even in the case of body leaks or the occasional spilling of something inside. Generally, plywood can get wet and dry out and be pretty much OK (which is not true for OSB).
The plywood that comes in buses from the factory gets badly rotted because it gets soaked for long periods of time.
Old 02-22-2021, 06:18 PM   #6
Thank you so much for the help!
