Old 02-01-2019, 11:22 AM   #481
Coachwork: IC
Chassis: IC
Engine: T444e, 7.3
Rated Cap: 12
makes up for the solo seat removal!
Hahah exactly!
consti2tion is offline   Reply With Quote
Old 03-31-2019, 09:11 AM   #482
I'm gonna have Ronnie drive this bus and have a look at whatever is causing the driveline vibes at highway speeds. Its barely there till 55 or 60.
Hopefully is not something major but ready for whatever. I love driving this bus and I really want to start using it a LOT!
Roll Your Own Build Thread
Old 03-31-2019, 09:21 AM   #483
brokedown's Avatar
Drive shaft out of balance maybe?
Old 03-31-2019, 09:29 AM   #484
Its possible but I think its the carrier/support bushing, the ujoints, or a combo of all that but Ronnie is a master of machines and has suggested with the pinion angle its got and the symptoms that its possible the pinion bearing is shot. If the rear ever comes apart I'm popping for a 3.90 ratio so I can run 11R's.
I want to replace anything suspect and also do new shocks and bushings on the rear.
Old 03-31-2019, 10:08 AM   #485
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
had similar problems at those speeds in a long wheel base HD crew cab - turned out to be the steady bearing - quick fix on the side of the highway to replace it and we were on our way again
Old 03-31-2019, 12:14 PM   #486
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Usually if the pinion bearing is wore out the pinion seal is leaking way before that.
The center support bearing/carrier bearing/mid shift bearing etc...
Rubber usually starts dry rotting and let's the bearing float around more than it should.
I would start there and if the money is there then I would replace all u-joints,pinion seal and tranny tail shaft seal while it's all apart.
Good luck
Old 04-01-2019, 07:14 AM   #487
Brewerbob's Avatar
This. Had an RX-7 that did this from about 57 to 70 then it would smooth out again. I figured it was a wheel bearing or something like that and ignored it. Then driving back to work from lunch one day, it decided to spit the driveshaft completely out. I saw the little bit of gear oil under the car (too low for a good look) and figured I blew the engine. Wasn't until I had it up on a lift that Hey, there''s something missing here!! The bolts at the dif were loose. 2 were missing and 2 were sheared.
Old 04-01-2019, 07:19 AM   #488
Brewerbob's Avatar
Any idea what that'll cost without the new gears? Shocks can't be all that cheap on a bus.
Old 04-01-2019, 07:27 AM   #489
remember to always balance driveshafts as a set. and when you put them back together keep the orientation as its balanced.. I always paint a line along my shafts so the phasing and balance is kept .. ie the splines go back together exactly as they were picked up at the shop.
phase your U-joints.. depending on your bus you may have U-joints on multiple shafts... getting them the most in-phase will give you the smoothest run...
U-joints should be in phase within the same shafty if it is manufactured correctly, however it you dont phase shaft to shaft you can get vibes..
a good driveshaft shop when balancing a set of shafts should also put the shafts together so that U-joints are phased shaft to shaft..
Old 04-01-2019, 07:47 AM   #490
SHocks are around $75 each.
Old 04-01-2019, 07:50 AM   #491
Mine has only one shaft. It looks newer and says "spicer lifetime" on the sticker.
IDk what's original on the bus but I know the gears have been changed from 4.10 to 3.42.
Old 04-01-2019, 08:13 AM   #492
Brewerbob's Avatar
Cheaper than the damn car. What the hell?!!?
Old 04-01-2019, 08:18 AM   #493
$35.58 each-
https://www.ryderfleetproducts.com/g...us-p-gab-83102
Old 04-01-2019, 08:38 AM   #494
wow.. freightliner does things different.. even my red bus has a 2 piece.. one piece from trans to carrier and then another piece carrier to rear diff...
Old 04-01-2019, 09:10 AM   #495
That's how mine is. I wasn't counting the little shaft from the trans to the carrier.
Old 04-08-2019, 12:51 PM   #496
Thanks to Tango I've got BEEFY looking cooler for the transmission!
Very cool.
This bus is coming together, albeit very slowly!
Old 04-11-2019, 10:01 PM   #497
oricha1984's Avatar
Engine: gasser probably
Hello,
Good to see you working on the bus.
Be well,
Raul
oricha1984 is offline   Reply With Quote
Old 04-12-2019, 05:40 AM   #498
Originally Posted by oricha1984 View Post
Hello,
Be well,
Raul
Raul! How you guys been?
Old 04-12-2019, 05:42 AM   #499
Ronnie came over and drove the bus... Then he got under there and showed me how the u-joint has ONE spot on it with a little play. That's causing the vibes.
That man Ronnie is AMAZING. He's got me wanting a steam boat haha!
Old 04-12-2019, 07:32 AM   #500
Brewerbob's Avatar
