04-12-2020, 12:51 PM
#641
Two brand new batteries installed on freshly painted tray. Note the scratch to the right of the batteries. These things are a pain. They get scratched up as soon as you use em!
04-12-2020, 01:34 PM
#642
Year: 86
Chassis: Ford B700
Engine: 8.2
my thomas had a piece of plywood under the batteries in the tray?
might be why i had to build a new slider tray?
cause the plywood held moisture and rotted it out?
is the plywood even needed?
was taught along time ago that when charging a battery to never set it directly on the ground or directly on a metal work bench so i never really questioned my plywood in the bus but now that i think about it all of my old trucks had the battery setting in a metal tray with nothing in between?
HUH?
04-12-2020, 02:12 PM
#643
HUH?
Yeah, that thing about the batteries on the ground or concrete is an old wives tale. I used to believe that. But I've since found out it was just a myth.
04-12-2020, 02:31 PM
#644
Rated Cap: 34
Thanks for the pic.......first time I've seen (or maybe noticed) those tray locking levers......would be a worthwhile addition to my bus.
04-12-2020, 02:51 PM
#645
Yeah, or you could drill a hole through the tray and the bottom of the compartment it sits in and run a bolt though it. The levers are easier to use, the bolt is easier to do.
04-12-2020, 02:54 PM
#646
I do find the levers make nice handles to pull the tray out with.
(My rust on rust has a lot of resistance...)
04-12-2020, 05:27 PM
#647
Engine: 345 international V-8
Oh no you scratched it has to come all back apart and start over....
Nice job, really.
We bummed around Georgia a bit last week staying away from people just us and the river on our boat. Missed seeing you two.
04-12-2020, 08:19 PM
#648
Nice job, really.
We coulda probably maintained 6-8 feet easy enough on the boat
Glad yall had a nice cruise, though, man. Good to hear yall are well and safe!
04-12-2020, 09:56 PM
#649
Sure 'nuff does! I use them even after I rebuilt my compartment with new bearings. It is now slowed down by all of the parallel runs of 2/0 wires connecting the four batteries in parallel and to the chassis and house.
04-13-2020, 06:46 AM
#650
Bearings??
04-13-2020, 07:27 AM
#651
Bearings??
Yeah, there are two on each side of the tray.
Did you not see them when you painted?
04-13-2020, 08:14 AM
#652
You're the only one that has them! I look fwd to seeing 'em one day so I can replicate my missing pieces... unless I get lucky at a junkyard one day...
04-13-2020, 08:35 AM
#653
Mine has no bearings or anywhere they'd go. Maybe yours has em since you run twice the batteries as mine.
04-13-2020, 10:03 AM
#654
Unless it's one of those weird "build your bus" options...
Our battery boxes are way taller than they need to be...
Our trays are meant to sit on 1" roller bearings in frames strong enough to hold the weight of the batteries.
Native posted pix to my "build" thread but I'm sure he has them elsewhere too
of how he rebuilt these parts.
04-14-2020, 01:57 AM
#655
You have a build thread???
Yeah, I have a few pictures of that refurbishment. Wanna see them, Charlie?
04-14-2020, 04:05 AM
#656
In the 5 I've owned they've all come set up like mine now. Never have I seen bearings on a battery tray.
04-14-2020, 04:54 AM
#657
Here you go:
The tray slides are much like a drawer slide. The bearings are at the ends of the slides, one at each end os each half of the slide. There are two slides per tray. In the picture above, the bearings look like washers.
04-14-2020, 05:02 AM
#658
How many batteries did it come with?
04-14-2020, 05:56 AM
#659
There were two in the box, but it was designed for three.
04-14-2020, 06:33 AM
#660
Mine looks like it was as well. But all mine have just been flat flanges that slide on the compartment floor under a lip.
I wonder if yours originally had an 8D.
