RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-24-2020, 12:16 AM   #1
Help with raising roof!
Hi, I have a 2004 GMC Sav (5 windows, excluding drivers side window). I want to raise the roof by 6-12" or so but I can't find any videos or pictures of ppl who has done it on a short bus. I am wondering if you can give me any advice on how to do it? Do you recommend doing it at all? If so, how would you go about it? Have you or know someone who has done it? Of do you have a link or something/advice for me. Anything information is helpful.
Thanks.
Maxman360 is offline   Reply With Quote
Old 11-24-2020, 05:31 AM   #2
DawgBüs's Avatar
Year: 1982
Coachwork: Ford
Chassis: E-350; 4x4 Minibus
Engine: 351c.i.
I used the same method as the full sized buses to do my shorty. Weld some temporary "jacks" from 1" square steel tubing into the pillars, cut, lift, level, weld in new supports, remove jacks. Watch this guys videos, he's got a lot of info and details: https://youtu.be/ooGztjaHpMQ
-Travis & the DawgBüs
<<1982 E-350 cutaway, Collins Bantam ext. body, Maximum 4x4 F-350 drivetrain conversion>>
DawgBüs is offline   Reply With Quote
Old 11-24-2020, 08:18 AM   #3
Thanks.
The structure is the same as a full-sized bus so you'd do a roof raise the same way - just with fewer ribs to cut and splice. I think people don't generally raise the roofs on short buses because they're so packed with stuff inside that you don't do a lot of walking around anyway. But there's no reason you can't do a raise.
musigenesis is online now   Reply With Quote
Old 11-24-2020, 08:27 AM   #4
@Dawgbus,Thanks for link. Do you mind sharing a couple of pictures of yours?
@Musigenesis, thanks for the reply, you are absolutely right.
