Old 03-12-2021, 08:59 PM   #1
Hitch for my shuttle
2013 chevy shuttle on van chassis, 6.0, dually, looking for trailer hitch, will a regular chevy van hitch fit?...thanks
Slickster is offline   Reply With Quote
Old 03-12-2021, 10:18 PM   #2
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Depends, but I would say so. Some, if not most of these were on Workhorse chassis instead of the regular van chassis, so the mounting points and frame rail spacing could be different. However, I'm not sure Workhorse was still in business by 2013. You can try calling a GM dealer parts dept with your VIN and find out what your chassis is, probably depends on the GVWR.
Old 03-13-2021, 06:27 AM   #3
Thanks, I'll try local GM dealer, maybe pick up a new vette while I'm there....
Old 03-13-2021, 10:36 AM   #4
Year: 2008
Coachwork: Aerotech
Chassis: E-450
Engine: 6.8/415 Ford
I recommend posting on a different board if you intend to tow with a the Vette.
___
You can also get under the shuttle get some measurements and ask the folks at etrailer.com. They are very helpful. You may as well search their website for keywords to see if someone has asked the same question as yours.
Sander is offline   Reply With Quote
Old 03-13-2021, 11:01 AM   #5
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Probably not.
Typically the frame rails get "extended" by the bus manufacturer, changing the van mount configurations.
I had to fab mounting brackets to adapt a van hitch to mine.
YMMV.
Good luck...
Old 03-13-2021, 12:01 PM   #6
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
no a standard off the shelf hitch will not work.
my 04 3500 was extended from the factory and the mounting holes are not there.
i am in the planning stage of building my own and or building a whole new rear bumper?
if you read the ETRAILER literature it specifically say not for cut away chassis.
Old 03-13-2021, 02:06 PM   #7
Year: 2008
Coachwork: Aerotech
Chassis: E-450
You are absolutely right. They offer nothing standard of the shelf, but do have some multi-fit hitches that will require either the 7 inch drop or the 16 inch brackets.
Here's 1 example of many: https://www.etrailer.com/question-137567.html
Old 03-13-2021, 03:56 PM   #8
Thanks for the great info....there is a hitch for the chevy express that has multiple holes in the cross beam, will measure distance between frame rails, etrailer is a good resource, thanks....
Old 03-13-2021, 08:30 PM   #9
Etrailer has expandable hitches, one will surely fit, bus is an 07 btw....thanks again
