Old 02-16-2016, 12:51 AM   #41
Low594's Avatar
Chassis: Ford E-450 Super Duty
Engine: PowerStroke 7.3L Turbo Diesel
Rated Cap: 14,000 lbs
Over the weekend we got the whole lower half of the bus painted brown. Gotta complete the cab and the top half then hit the trim with black and it'll be done. Its a huge task!
Also accomplished getting the passenger seat mounted with forward, 90*left and reverse locking notches cut in the swivel. As well as making the inside a complete disaster! I know what I am doing for the next couple days after work.
These are the bulb housings I got off Ebay a while back. They are drop in and upgrade the headlights to an H4 bulb, with LEDs(can be wired to running light, turnsignal or any source). It is a glass lens, so no polishing every few years like composites! I just received the Cyclops Adventure Sports 3600 lumen LED bulbs for them!
Ive been running these bulbs in my Vstrom for a year with no issues, plug and play!
Low594 is offline   Reply With Quote
Old 02-16-2016, 08:25 AM   #42
Sweet! I am hoping to do the same upgrade on my old 7" round lamps.
Old 02-16-2016, 08:31 PM   #43
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
Love the bus. I am currently doing the same thing. I picked up a 1990 30' Bluebird with a 12 valve cummins just to haul bikes. It has the side wheelchair lift in the rear, and bikes fit in perfectly sideways. (Bus came with tie-straps and rails built into the floor). I once converted an old motorhome to a hauler, but it was a major POS, and a PITA to use with 4 bikes loaded. Keep up the awesome work!!
SDR76 is offline   Reply With Quote
Old 02-17-2016, 07:05 PM   #44
Low594's Avatar
I highly recommend Cyclops Adventure Sports, quality products and quick response to emails!
Thanks, I'll be watching for your Build Thread!
Old 03-04-2016, 10:29 PM   #45
Low594's Avatar
Its been raining off and on and I have been working a ton of hours, but the paint is coming along!
Old 03-13-2016, 11:21 PM   #46
Low594's Avatar
Yesterday after working some overtime, I got alot done on the bus! I installed the stereo & speakers and then layed down the Travertine tiles!
Old 03-14-2016, 12:02 AM   #47
Robin97396's Avatar
Travertine huh? That's kind of hard to follow. That paint job looks really nice.
I like the extra lights too. Have you thought of replacing the old large high up blinkers with lights?
Old 03-14-2016, 08:55 AM   #48
In many states, driving (white) lights up that high are illegal.
Old 03-14-2016, 11:38 AM   #49
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
They are in CA. They don't even have to be on. I'm sure that's why he has them covered.
I'm hungry!
You Gotta Let Me Fly
Old 03-14-2016, 12:22 PM   #50
Robin97396's Avatar
So your point is it's illegal to replace those large blinker lights with headlights? But at the same time it's ok if three lights are mounted in between the original stop/blinker lights? Someone better warn the 4x4 community.
I've seen old timers put headlights in those high up blinker positions. Don't know if they got in trouble or not. I don't believe they used those additional lights for driving, rather using them as fog lights in front or back up lights in the rear.
I like what Low did with the lights but they don't appear to be covered, and considering their current position I can't imagine that they would be any more or less legal if they replaced the old blinkers. Low just gave his bus a uni-brow.
Old 03-14-2016, 01:17 PM   #51
Moderator
crazycal's Avatar
I'm too tired to explain my post if that is what you are referencing. Read it again.
Just because people do things doesn't make it legal. I see people put blue lights on their cars, even forward facing ones. Only cops can do that in CA. Fire and ambulance can't do that.
I'm hungry!
Old 03-14-2016, 01:20 PM   #52
Might be cause most off-roaders aren't 12 feet high.
Old 03-14-2016, 01:42 PM   #53
Robin97396's Avatar
Tango; the very top of my blinking lights are 8' 4" off the ground, not 12 feet, and that's comparable to the height of the fog lights of many four wheel drive trucks.
Crazy; don't need to read your message again. You wrote very simply the first time. You don't need to be insulting just because I don't agree with you. People don't generally use fog lights while driving around in public. I think there's a distinction between driving lights and fog or utility lights.
Low; I think Low probably uses those lights in the appropriate setting. A question for Low. Are those three lights covered? I don't see anything illegal about them.
Old 03-14-2016, 02:03 PM   #54
I don't either...but many State Police do.
Old 03-14-2016, 02:06 PM   #55
Moderator
crazycal's Avatar
I wasn't being insulting. I am tired. His lights are covered. He is in CA. He is completely legal. Drive with those lights uncovered and he is outside the law. He might pass 2000 officers before one decides to pull him over and write him a fix it ticket. That's the way it works.
As far as the 4x4 community is concerned, they can figure that out for themselves. I see some of their trucks that they thinks are sooo cool but have dozens on violations. My motto is live and let live, except for the douchebags with their stacks rolling coal. If I was a cop, I''d have those guys pulled over in a heartbeat. It's because of jerks like that our diesel trucks need to get smog checked. Pages of violations they would get. Headlight height, tires sticking out past fenders, the list would go on and on and on.
What did your mother tell you when you were little and you got busted for something? "Just because Johnny did it, doesn't mean you can too. If Johnny jumped off a building, would you do it?"
I'm hungry!
Old 03-14-2016, 02:42 PM   #56
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Johnny was so cool... lol
Old 03-14-2016, 03:01 PM   #57
Robin97396's Avatar
Was Johnny jumping out of a barn into a pile of hay?
Old 03-14-2016, 03:30 PM   #58
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I like the idea of the wire shelving in the overhead. Sure gives you more storage space.
Old 03-14-2016, 03:45 PM   #59
Robin97396's Avatar
There are a number of closet organizing systems at the home stores that seem to have this type of wire shelving. Excellent idea.
Old 03-14-2016, 06:09 PM   #60
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Most home improvement box stores will cut to fit the wire shelves. Kinda handy for space and time with blankets and such.
