Old 04-30-2024, 10:51 AM   #1
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
Managing Roof Space
I have a 7 window dog nose Blue Bird. I have a functioning factory installed AC system which I want to keep-- it has one large evaporator mounted in the back. For that reason I have chosen a Houghton roof mount heat pump unit.
Here is my problem-- I also want to mount a MaxAir Fan on the roof, and if I mount the AC unit and the MaxFan longitudinally on the peak of the roof-- it will reduce my solar panel space. (I want three 45 inch wide 400 watt panels...)
I just looked at photos of a build by Yellow Chrome on a short bus, and they have mounted a roof AC unit side by side with a MaxAir Fan.
Anyone else ever done this? Roof leaks?
Feedback please.
PorchDog is offline   Reply With Quote
Old 09-07-2024, 09:05 PM   #2
This is the AC I have mounted on the roof of my bus, with maxair fan and 3 64.57-in x 39.06-in solar panels. Still have the emergency hatch and installed a skylight in my shower. I can take some pictures tomorrow if you're interested
TJ503 is offline   Reply With Quote
Old 09-08-2024, 07:53 PM   #3
Rated Cap: 34
I bet your bus is longer than mine. Photos would be nice. \\Thanks!
Old 09-08-2024, 11:20 PM   #4
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Feedback please.
I have a Houghton A3800 on Freddy D's roof. It moves more air than any other rooftop unit, 350cfm, I believe. I wouldn't mount it tilted though, as per the installation instructions. The condenser makes it own rain (condensate) and the built in drains have a gravitational flow.
I understand the need for an exaust vent, too. Have you considered a different model of Maxxair fan? They have models for horizontal and even diagonally mounted. This model is built for the purpose you described, including wall mounter. (Saving roof space.)
click on the photo for more details
