04-17-2020, 08:40 AM
#261
Chassis: Collins
Engine: 6.6L LMM Duramax
Originally Posted by Phatman
To quote an old George Carlin routine, “why do you want to heat hot water”? Wouldn’t it be a cold water heater or a hot water cooler ?
Lol how about "Excel Tankless Water Heater" ????
04-17-2020, 08:59 AM
#262
Hahahahaha. I used to have a supervisor every time he would say “ hot water heater “ he would turn and give me that “go to hell” look.
04-17-2020, 09:58 PM
#263
Chassis: Collins
I got the rear porch light installed. I picked up a rubber grommet assortment from Amazon that had come in handy. This particular light is led and came with clear and Amber lens...
I put a couple 2x3 inside that will be the wood that the water heater screws in to.
I put some more paneling up as well... I think I'm still going to make some flashing that will go behind and above the water heater to direct the heat/fumes up into the range hood.
04-18-2020, 07:22 AM
#264
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I got that same grommet kit this week. Already used a bunch.
I hadn't thought of putting my "cold" water heater in the kitchen. I don't like where it's sitting right now but I would have to run cold all the way to the front half of the bus then hot all the way back to the shower. I wonder how much water I would waste that way to get hot.
04-18-2020, 07:58 AM
#265
Hahahahaha. Seriously though. I believe I will mount mine literally right by the shower. I’m not sure though, I’m not sure how much I could trust being ventless.
04-18-2020, 09:31 AM
#266
That's where mine is for now. No plumbing yet But that's my space for a washer too. I don't like the limited room. The other side of the shower it would be above my bed.
I have all my windows. It's easy enough to open them to vent when I shower. My roof fan is right there too. I'm not too worried about the venting.
04-18-2020, 08:46 PM
#267
Chassis: Collins
My fresh water tank and City water connection will be within 5' of the heater and my outdoor shower is right in between. So I should be good.
04-18-2020, 08:51 PM
#268
Chassis: Collins
The cold water heater I have is advertised as "ventless" and where I'm mounting it is under the range hood which vents to outside the bus. I decided to mount it under there for extra peace of mind because I was worried about the "ventless" feature... I shouldn't have anything to worry about with that added safety...
04-18-2020, 09:00 PM
#269
Out a recirculating loop on the heater line. That will give you hot water "instantly" anywhere in the rig.
04-18-2020, 09:39 PM
#270
Year: 97
Engine: 5.9L Cummins 12 valve
I have a 2004 Duramax and it’s a problem with fuel is that the fuel filter does not seal really well too it’s bracket. It loses its siphon and fuel stops going to the engine. There is a pump button on top of the bracket that forces it to re-prime and then everything’s good again. Used to happen to me about once every month or two, especially if it was parked for several days or more
04-18-2020, 10:39 PM
#271
Thanks for the tip Jack !!
04-19-2020, 07:39 AM
#272
Chassis: Collins
Sounds like an air leak for sure because it happens when sitting for days. Is this a truck or van chassis? The van chassis have a small pump in the tank but the trucks dont. But many people install aftermarket pumps on their rigs because of your problem. I installed a twin pump kit mainly due to injector issues... mine always started fine but would throw the P0087 code low fuel pressure because my injectors were returning to much fuel back to the tank when I would run it hard/ and when it was hot out.
04-19-2020, 09:47 PM
#273
Chassis: Collins
Water system mock up
Please let me know what you think and if I'm missing anything? I have the water tank mocked up with the pump, accumulator, City water connection, etc. The small white hoses are the pump silencing kit and I will have them wrapped around as shown.
The city water connection comes in from the back of cabinet. There is a check valve there you can't see before the PEX. The T will supply the water heater, etc and rest of bus.
From the tank side is a check valve also, then winterized kit (bypass valve) then the hose goes around to the strainer then pump. Out of the pump the other white Hose will go to the accumulator. The back side of the accumulator is where the T is I mentioned above.
Im going to order another 90 degree fitting like you see on the strainer side to make the silencing hoses not be kinked.
Anyone see any issues? Large white Hose is fill hose and top clear line is vent line for the fill hatch.
The other fitting is 1.5" thread on the bottom. I will neck it down for a drain.
Other questions are is my tank supported enough? Sitting on 3/4" plywood and 2x3s front back to keep from sliding and over the top as well. It is only 13 gallon tank. Thanks
04-20-2020, 11:40 AM
#274
Looks legit to me. It looks plenty supported with what you have. I see you have a lot of curved tubing as well... I do too because I wanted to keep max water pressure, as angle joints lose a small amount of pressure. Well my pump is under the stairs and the sink is about 10 feet behind it, and there’s so much water pressure I should’ve just used elbow joints instead of trying to smooth out the curves. Just something to consider.
Also my pump is still loud as ****, even with the accumulated and quiet fittings.
04-20-2020, 11:45 AM
#275
Chassis: Collins
Originally Posted by TheArgobus
Looks legit to me. I have my pump mounted under the bus and it’s still loud as ****, even with the accumulated and quiet fittings.
I read on a review on Amazon for the silencing kit a couple of good ideas. One person put insulation on the hoses. Another person mounted the pump on a board that wasn't screwed down and sat the board on some shelf liners and it was very quiet. Gives me a few ideas to try if needed...
04-20-2020, 04:40 PM
#276
Coachwork: Bluebird, Collins
I didn’t think about the noisy pump lol. What do stealth campers do for a pump? Maybe they have those foot pumps.
04-20-2020, 05:00 PM
#277
Chassis: Collins
Ha! Good point! I don't even know if I'll notice it how it is... I'm not going to change anything for now because of noise... I want to make sure I'm not missing something obvious with my plan for water system...
04-20-2020, 05:04 PM
#278
Year: 86
Chassis: Ford B700
Engine: 8.2
they make rubber bushing for the mounting holes of the pumps or you can by vibration isolation pads usually found around HVAC suppliers can go from anything from cork to rubber to spring isolaters
04-20-2020, 06:42 PM
#279
Chassis: Collins
Thanks! I will look into those if it's too loud for us when we get it finished! As long as it's taking me, my hearing might be worse by the time we get it done!! Lol
05-22-2020, 05:48 PM
#280
Chassis: Collins
More progress
Here's a few pictures of my finished cabinets!! We went with a weather wash pined finished with a clear satin polyurethane. I was also able to get the new countertop test fit as well as my faucet and workstation sink. I've started to clear the bottom side and will clear the other side tomorrow. I also figured out my venting for my gray and black water tanks and now have them vented. I went out the wall under the drip rail and then went up. I will install clamps and permanently install a rotating cap on top.
