06-24-2019, 08:48 PM
#161
Chassis: Collins
Engine: 6.6L LMM Duramax
Originally Posted by plfking
FWIW.....I never felt any air-flow through mine, and skinned over it just to eliminate the potential for a later leak.
Hope you have a totally boring and uneventful trip (bus-wise).
Thanks for the follow-up! I think I'll just cap it from the roof!! I hope I have a boring drive as well!!! We're installing the rooftop AC right now... Having to do some custom work as the AC I bought was for ducted system and I'm modifying to make it have a register...
06-24-2019, 09:43 PM
#162
Chassis: IH 3800, 8 window
OK, I see how ya're!
Got me all paranoid about condensation up there, and now you're gonna do what I originally stated my intent to be!
Some people's kids...
For a wonderment, I actually knew which tote full of pending supplies they were in!
So I lied... Forgot theres actually 4 blocks of LEDs per string...
Picked 'em up on a whim at an auto parts store, buying replacement bulbs for the bus' B/U lights. Think they'll work fine with my minimalistic mind-set on my mods.
Originally Posted by Sleddgracer
thanks - l'll look into that
06-25-2019, 12:21 AM
#163
Chassis: Collins
Some people's kids...For a wonderment, I actually knew which tote full of pending supplies they were in!
Picked 'em up on a whim at an auto parts store, buying replacement bulbs for the bus' B/U lights. Think they'll work fine with my minimalistic mind-set on my mods. Attachment 34930Attachment 34931
Lol sorry! Didnt mean to get you all riled up!
I got the crap around the bus all cleaned up so I could pull it out of the shop this evening. It's only been in there a month or so and had stuff all around it!
I used the skid steer to raise the AC up to my father in law and he slid it off the forks onto the roof. It worked pretty slick. We got it bolted on! I might be wiring it up down at the lake with my dad's help... probably won't have time tomorrow...
06-25-2019, 06:36 AM
#164
Alright... I'll let it slide... THIS time!
Using a skid steer to hoist the A/C roofside is an awesome engineering control! I had to rig a rope sling, and pull it up, sliding along my ladders rails, riding on a cardboard sheet. Good times...
BTW, sure hope you didn't slide the unit around on it's foam gasket. That'll screw it up in a hot NY minute!
06-25-2019, 08:28 AM
#165
Chassis: Collins
Good point! The gasket was in a great shape! Very thick foam rubber type of material. So we set the AC on a board on the forks. Then he slid the board and ac over along with the board. Then just tipped the AC up and we pulled the board out.
06-25-2019, 08:58 AM
#166
Well done, sir. That's just what I did with mine and it's cardboard slide- no harm, no foul.
The gasket is amazing stuff, nary a leak to be seen.
But it has incredible braking qualities, so sliding it unprotected'll break it...
06-25-2019, 11:53 PM
#167
Chassis: Collins
I didn't use the boat seat swivels. I decided I needed the bed to slide as well in order to maximize my space. With no slide would mean around an 18" deep counter top. With the slide I should be able to go over 24".
So a few chicken scratches on a piece of insulation later I had an idea... Some 1" sq tubing is the frame and a small tab to bolt to the chair rail for support. I ended up putting some 1/4" plywood in the base of the bed frame as well. For now I just have a few tie downs to hold in place. I'll make a locking mechanism later.
06-26-2019, 12:02 AM
#168
Chassis: Collins
A few more details on the bus done today. I welded a receiver hitch on the back of the platform.. I also made some flashing for the rear door. I used the rubber seal from the top hatch on the bottom. Of the door. I used some 3m adhesive to glue it to the door.
I bought some press on rubber seal from Amazon. I used it on the sides and top. I believe it is 5/8 or 3/4" but on the hinge side it isn't quite thick enough. I'll have to get some thicker for that side.
The AC I bought was for a ducted camper. So I modified the bracket with 4" holes and used my round vents I had planned to use for my heater. Ill get more for that later...
06-28-2019, 04:16 PM
#169
Chassis: Collins
Skiatook OK
Well we made it.... My wife and kids followed me in the truck. No seats in the bus yet... The 4 hrs 15 min trip took about 6 hrs. We had to stop and feed the 4 month old once and I had some issues with the bus. I had the P0087 code show up on me again and went into limp mode a couple times. I also had some transmission problems. It ran great until it got warm (92 degrees or so) Wednesday afternoon. So far, we've had a blast. The bus gives us a cool place to sleep! The two oldest kids are in memaw and pepaws camper and the little one with us.
We pulled in around 9pm Wednesday and spent the next couple of hours wiring the RV AC up with the help of my dad and brother in law. We got it going and it works great! We also wired up the fridge but it's not working. Hmmm maybe a circuit board? Any who quick update... The BOATs maiden voyage!! We made it and enjoying our own space!
06-28-2019, 10:10 PM
#170
Coachwork: Bluebird, Collins
Hey, my Chevy short bus is giving me code 87 and in limo mode, limp mode, not limo mode lol. I’m not sure what’s causing it yet??
Thanks for sharing your adventure and best wishes for the road.
06-28-2019, 10:34 PM
#171
I like how the bed flagrantly violates the instructions above the door...
06-28-2019, 11:14 PM
#172
Chassis: Collins
Is it a Duramax as well? What year? Is it an LMM like mine? Mine is low fuel rail pressure. I've done a lift pump and a tune now. It appears I might need injectors. Not super happy as it will be over $3k...
06-28-2019, 11:17 PM
#173
Chassis: Collins
Haha! I noticed that. I always think I need to take that sign down then forget about it.. lol
Then again... I usually don't read instructions... Lol
07-02-2019, 07:05 PM
#174
Chassis: Collins
We made it home!
Well the bus went almost a 500 mile round trip. We made it back without too many issues. I have some transmission problems I need to line out. Most of the way home it was in 3rd gear and no overdrive. We had a cool place and comfy bed and privacy. I think my wife is all about the bus now.
I hooked up our Excel hot water heater for our outdoor shower and it worked great! Everyone in my family used it. A few bumps in the road, but all in all an amazing trip and a first for the bus!!!
I should receive an upgraded control board for my fridge today. I hope it fixes my issue.
07-02-2019, 10:01 PM
#175
My chevy work truck has a bad shift solenoid and no OD.
07-02-2019, 11:29 PM
#176
Chassis: Collins
Thanks for the tip. I'll do some research and might try switching that out!
09-08-2019, 11:58 PM
#177
Chassis: Collins
Update...
I haven't been on here for awhile... We made a few more camping trips and have now brought it to 2 home games to tailgate at K State football games. I mounted a TV inside and made a few mounts on the back platform for an outside tv during tailgates. I also made a mount to throw the dish up easier. I made a mount to bolt the dish tailgater to and used conduit to hold it up. So far it's working great. The fridge inside works great for tailgates! I haven't had to bring a cooler! The little 2200 watt generator runs the fridge, TV's, Wally and a crock pot on low.. plans to buy a bigger one next season that will power the AC as well.
10-01-2019, 11:14 PM
#178
Chassis: Collins
Tailgate Season
Well not a lot new on the bus. I don't want to dig into it too deep during football season. I did run another HDMI cable and set up a blue ray player to the front tv in the bus. This will allow my kids to watch a DVD inside the bus in the future...
I built a step for the rear platform this evening. I used all stainless other than the tube that goes in the receiver hitch. I was going to make in fold up in case I forget to take it out, but I decided to get it done tonight. The stainless powercat tacked on was the finishing touch!
10-13-2019, 09:47 PM
#179
Chassis: Collins
Heater install
I had some time this weekend to cut another hole in the side of the bus. This time was for the heater. It is a heater out of a camper. I got it roughed in. I'll still need to pull the cover back off and seal up the shroud with some rope caulk or some sort of sealer. I drilled a small pilot hole for the propane line before I installed the heater. I'll need to run propane line and 12v wiring and wires to my thermostat. Good news is, the hard part is done.
I built a "stand" out of 2x3s and lined with 1/2" polyiso insulation. In the camper the intake was in the floor. So I just raised the base of the heater up to make the intake. I set it up for temporary right now. Eventually when I build the cabinets, the intake will be at the bottom face of the cabinet.
10-26-2019, 10:35 PM
#180
Chassis: Collins
Well no pictures... But what a game!! Had the ol bus tailgating this morning. Was 33 degrees F here in Wamego KS this morning when I fired her up. I had it plugged in overnight and then plugged in an electric heater inside for an hour before we headed for Manhattan for the KState game against OU. It took the chill off inside the bus. I haven't got propane lines ran to the heater. I'm hoping to have that operational in the next few weeks! More to come...
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
