Old 05-18-2020, 05:25 PM   #1
Opinions of this Shortie?
It is listed at $4,900. Does that seem right? Anything I should watch out for? I'm scared to throw my precious pennies at something that will be tons of problems. This looks promising though.
https://philadelphia.craigslist.org/...123373532.html
FACTORS:
* I'm looking for something to convert and insulate and still be able to stand up in, without a roof raise. I'm 5'11".
* I don't plan on driving around a ton, though some trips (even potentially a cross-country one might be nice. Daily life will be as a quarantine bus in the Philly area.
I realize that I'll need to learn about the engine if I really am to commit to any significant travel - is this a good one to learn on, depend on, get parts for, etc?
Thank you for looking, and for the knowledge this forum has provided.
Big Tim is offline   Reply With Quote
Old 05-18-2020, 06:29 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
can almost guarantee the 6.0 motor is the reason they are selling.
stay away unless you have thousands more to bullet proof it?
it can be a good motor after that?
Old 05-18-2020, 08:44 PM   #3
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
First, it's a 6.0 PowerJoke.
Second, it's a dealer stupid enough to buy a 6.0 PowerJoke for resale.
Third, the price is about half of what it will likely cost you in repairs.
RUN, FORREST, RUN!
Don't buy a 6.0 diesel Ford. EVER. AT ANY PRICE.
Old 05-18-2020, 08:55 PM   #4
Hard pass on that one.
Old 05-18-2020, 08:57 PM   #5
At least it's on a 450 chassis and not a 350...
The engine either is, or is not in good running condition at the moment.
check it out and see...
David
The Murder Bus
Old 05-18-2020, 08:58 PM   #6
04+ are all 450's aren't they?
Old 05-18-2020, 09:12 PM   #7
I only know the 450 is a heavier duty frame & suspension -- seems a much better candidate (to me) for a build-out than the 350's...
David
The Murder Bus
Old 05-18-2020, 09:22 PM   #8
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Unfortunately, completely irrelevant when dealing with the 6.0 PowerJoke engine.
Old 05-18-2020, 11:23 PM   #9
It has a 14000 pound GVWR. I wonder how much the vehicle weighs in its current configuration. Any clue as to the interior height?
Old 05-18-2020, 11:43 PM   #10
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
As I said, irrelevant when dealing with the 6.0 diesel. These engines are bad news and should be avoided. A very common dirty trick to hide their problems is to clean or replace the coolant recovery tank, plug the overflow hose with RTV, then reinstall and fill with clean coolant to hide the coolant contamination. The listing honestly comes off as typical of a predatory dealer anyway.
Many a poor soul has been burned on these engines, so much so that it has generated at least several years' and several million dollars worth of lawsuits. Just say no. Navistar supplies this engine for Ford. Navistar has yet to build an emission-equipped engine that didn't have problems, and this one is the worst by far.
Check these out before buying any vehicle with the Navistar 6.0L diesel (aka the VT365).
Operative words being, "AT THE MOMENT". I'd sooner trust gas station sushi and nachos before I would trust one of these things.
Old 05-19-2020, 06:26 AM   #11
Wow thank you everyone. I thought the post looked a little sketchy, but the dimensions looked appealing. I've read over and over that it is best to start with the best engine possible - are there any of those E-450 shorties that have a good engine?
Old 05-19-2020, 06:29 AM   #12
Not 04+
If it were an 03 it would have the much more desirable 7.3.
If you want one newer than 04 I'd look for one with a GM gas 6.0 engine.
Old 05-19-2020, 10:37 AM   #13
Chassis: Ford e450
Engine: 7.3 powerstroke
Rated Cap: 20
Look for a 2003 or earlier! I'm waiting for a mechanic to eval a local e450 with a 7.3 before I make an offer (seller has no fixed price since they know it needs some work). There's a dramatic difference in the 2003 and earlier 7.3 engines (which have a very good reputation) and the 6.0 that replaced it which is apparently a big POS.
Good luck with your hunt!
Jocelyn is offline   Reply With Quote
Old 05-19-2020, 10:50 AM   #14
What about something like this?
https://asheville.craigslist.org/ctd...122609589.html
Old 05-19-2020, 10:51 AM   #15
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
I don't think there's a ton of difference between the E350 and 450 cutaway buses. Maybe 1 or 2 leaf springs in the rear at most.
Those 6.0s are bad. My bus company still has a couple dozen in the fleet. We have an '07 E450 with a Girardin body right now that has been sitting in the yard for the last 2 years because it develops an interminnent no start issue and cannot be relied upon for anything.
The mechanics hate them because access is bad (except for maybe the turbo/y-pipe area because the interior doghouse is surprisingly easy to remove).
Old 05-19-2020, 12:17 PM   #16
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
FACTORS:
Here is the listing when sold on Gov deals, just in case you're interested.
https://www.govdeals.com/index.cfm?f...31&acctid=3934
BamaBus is offline   Reply With Quote
Old 05-19-2020, 12:20 PM   #17
wow- good looking out! Its been listed as high as $5900 on FB- https://www.facebook.com/marketplace...0385701104433/
Quite a markup from $637 and some change!
Old 05-19-2020, 12:32 PM   #18
WIbluebird's Avatar
Rated Cap: 75
It's from that massive yard in DC that sells dozens of those heaps every year.
They're often listed as parts missing etc so I would never touch anything from there even if it wasn't a 6.0 Powerstroke.
Old 05-19-2020, 12:35 PM   #19
Yep. They're always sold as "not running" "tow away".
Old 05-19-2020, 02:06 PM   #20
Wow really impressive sleuthing folks. What a rip. I'm so grateful for the guidance!!!
