Old 06-07-2021, 04:31 PM   #1
Coachwork: Michael Corbier
Chassis: GMC Savana 3500
Engine: 6.5 Diesel
Rated Cap: 8-10 passengers and wheel
Q Straint anchor removal
Greetings,
I'm working on removing the Q Straint anchor point bolts from my bus floor. The bolts are frozen. Does this mean I have to grind off the bolts underneath? Suggestions please!
Corbi is offline   Reply With Quote
Old 06-07-2021, 05:58 PM   #2
DAVEHOLMAN's Avatar
Coachwork: Thomas Saf-T-Liner
Chassis: HDX with lift
Engine: Mercedes MBE 920
Rated Cap: 22
There's a good thread on this subject, with several methods discussed. Personally, I put a diamond wheel on my angle grinder, and ran right down the middle of the track. You can then pry up each side, and grind off the bolt heads easily
DAVEHOLMAN is offline   Reply With Quote
Old 06-07-2021, 07:03 PM   #3
Like Dave said. Carbide cutoff wheel on an angle grinder wear gloves and safety glasses.
Old 06-08-2021, 08:12 AM   #4
Engine: 6.5 Diesel
Good suggestionss
Thanks for these ideas. Since I have just attachment points not rails, I'll try removing the top part of the device with my current cut of wheel first to see if it works before purchasing a diamond one. I'll post a picture soon that shows what they look like.
Old 06-08-2021, 01:32 PM   #5
Engine: 6.5 Diesel
Photos attached
See photos of attachment points and under chassis nuts and bolts.
Old 06-08-2021, 01:45 PM   #6
These work great
https://www.acehardware.com/departme...E&gclsrc=aw.ds
And you can just cut the bolt off from underneath if it’s accessible. Wear eye protection and gloves!
Old 06-08-2021, 07:23 PM   #7
Chassis: IH
A nut splitter might work. I had the same system and rusted bolts issue. I was able to grind off some, sawzall a couple from below. One was obstructed by a toolbox from below so I ended up breaking out as much plywood as I could and using the sawzall between the anchor and sheetmetal floor, there was about 1/4" to work with.
Old 06-13-2021, 08:04 PM   #8
Engine: 6.5 Diesel
Qstraint removal update
The other day I worked on the removal of two attachment points. I made images of the process. The one accessable from below was easy with the angle grinder. The one from above with just the grinder, not so much. I tried to grind a line across, hoping to break the plate in two to remove and get to the brolt. I managed to do both at the same time, meaning Hitting the bolt head while cutting the plate.
Old 06-17-2021, 04:43 PM   #9
Engine: 6.5 Diesel
More on Qstraint
So, A new set of anchors. I changed tactics. This time I grinded from the bolt side to remove the anchor while leaving the bolt intact. Then, I grinded off the bolt head.
Old 07-01-2021, 01:16 AM   #10
Coachwork: Our hot little grubbies...
Rated Cap: Five Heelers
Hearing protection.
And warn sight-seers to stay clear... airborne debris is surgical.
LargeMargeInBaja is offline   Reply With Quote
demolition, floor help, short bus
