Old 08-01-2020, 03:51 PM   #21
Year: 2012
Coachwork: Goshen
Chassis: E450
Engine: V10
Rated Cap: 1 1/2 ton
Smile Finally found the rear air conditioning ports for my E450
I finally found the air conditioning ports for the rear air conditioning in my 2012 Ford E450, Goshen body shorty. They are over a heat shield and difficult to see.
Note this particular E450 has two independent air conditioning systems, one is the original compressor installed by Ford and matches the one you see when trying to order parts, one compressor was added, and the fan belt is longer than a standard E450 to accommodate the extra compressor. They are not the same compressor.
The refrigerant lines from the top compressor, the one for the rear, go over the engine, down over the driver's side of the engine, then under the bus just below the floor but over a heat shield for the exhaust pipe. The high and low ports to fill the R134a refrigerant are hidden above that heat shield and near the front edge of the condenser, both caps facing outwards. Neither port can be seen at all without looking from the side to see over the heat shield, and even then only a portion of the caps are visible.
The information sticker for the added air conditioning system that goes to the back is located under the hood on the right side. That sticker is filled in with a permanent marker, hand written, and not perfectly easy to read.
GaryTheRock is offline   Reply With Quote
Old 10-28-2021, 09:51 PM   #22
Chassis: 2002 Chevy express
Engine: 5.7, chevy
Howdy boys & girls
My 2003 Blue Bird 4 window has an air conditioner issue
The unit is on the rear ceiling. The 3 speed fan worked when purchased a year ago
Now Iím down to low only. I replaced the relays. Didnít help. Friends suggested replacing the resistor. I donít know where it is. Help would be welcomed
Thanks. Hayseed
Hayseed is offline   Reply With Quote
Old 10-29-2021, 07:46 AM   #23
ewo1's Avatar
Originally Posted by Hayseed View Post
Howdy boys & girls
Thanks. Hayseed
You ask a very general question so one can only give you a really general response....
Yes, a/c systems have a resistor pack that controls the blower motor speed.
In my Chevy Silverado, it is behind the glove box, up on the the blower motor housing.
You might want to go up on top, remove the cover, get the manufacturer specs and contact them about a blower motor resistor module, if it has one that is.
If it does not, the manufacturer will let you know.
Also, you might get lucky and find a wiring diagram on the inside of the a/c cover.
This is what the Silverado blower motor resistor looks like, yours will be different.
Old 10-29-2021, 07:50 AM   #24
in 2 of my A/C's my motor has 4 Taps for speeds.. so the speed control switch controls the speed, there is no resistor..
my Carrier unit has a resistor inside the evaporator. but the speed control switch must supply power to one of 3 wires that is input to the resistor..
theres a lot of things out there that are made.. what unit do you have?
Old 01-31-2022, 06:40 AM   #25
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Go away. 'Baitin.
Our Build: Mr. Beefy
DTA 360 info the_experience03 International | Navistar Drivetrain 22 06-29-2019 09:15 PM
Help & Info Please !! TheHobbits Conversion General Discussions 15 02-21-2013 08:05 PM
Info sources wewise Conversion General Discussions 0 10-29-2011 07:35 PM
bus info newtoskool Conversion General Discussions 1 07-29-2010 02:53 PM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
