Old 05-06-2020, 11:16 AM   #21
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Originally Posted by Native View Post
I was curious if you had overspray or tried it on the aluminum. Not to help it, but to see if it reacts. Aluminum is great in that when it oxidizes, it forms an oxygen barrier which stops the corrosion. However, electrolysis is an entirely different matter.
I did get some on the aluminum but it didn't seem to do anything. I didn't notice anything when I cleaned up before painting.
peakbus is offline   Reply With Quote
Old 05-06-2020, 12:47 PM   #22
joeblack5's Avatar
Year: 98
Looks great, how did you like the aluminum primer?
Johan
Old 05-06-2020, 05:17 PM   #23
That's a floor to be proud of!
Old 05-08-2020, 10:54 AM   #24
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Johan
The primer worked well. Being latex meant low odor which was nice compared to the Rustoleum oil based topcoat. The only places it didn't stick well was where I didn't get the Oshpho residue completely brushed off.
Old 05-08-2020, 12:11 PM   #25
Coachwork: Girardian Handicapped Commercial
Chassis: E-450
Engine: Ford 7.3L
Rated Cap: 9,000
Originally Posted by peakbus View Post
Yesterday and today I got the floors torn out.
You're right I never could have felt good about leaving mine in and building on it, knowing what I know now, having removed them!!!
mc11237 is offline   Reply With Quote
Old 05-17-2020, 09:21 AM   #26
Jfoster503's Avatar
Coachwork: Collins
Chassis: Collins
Engine: 7.3 Diesel Powerstroke Turbo
Wow! What a difference on that floor!
Jfoster503 is offline   Reply With Quote
Old 05-17-2020, 04:22 PM   #27
Great build, thanks for sharing!
Emidd27 is offline   Reply With Quote
Old 05-17-2020, 06:12 PM   #28
I got the floor cleaned up. It's amazing how much aluminum corrodes. Everywhere a screw or bolt passed through the floor, the aluminum is pitted. There are even a couple of holes. Nothing to the point of structural weakness, though I haven't delved into the driver's area yet. Galvanic corrosion between dissimilar metals is a big thing on boats, and apparently busses. Aluminum floor+steel bolts+wet plywood.
I applied Oshpho to the galvanized chair rail and will paint the floor and rails with Rystoleum Latex aluminum primer then paint.
I'm curious to see your experiences with that primer. I'm currently painting two aluminum bus windows black to match the ones already in my bus, and I'm using SEM self-etching primer and then black Rustoleum enamel. I fixed some peeling paint spots on my own windows with this and it adhered well and has held up pretty well so far, but I've never done an entire window with it before and I don't know how well it's going to last.
Old 05-17-2020, 10:13 PM   #29
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
It seemed to adhere well though I probably won't know long term as hopefully it will soon be permanently covered.
I have all the insulation cut as well as the finish plywood. Because of the limited headroom, I used 1/2" polyiso foil faced foam. It's not as compression resistant as polystyrene so I installed 1/2' plywood strips anywhere there will be significant weight above. Also at the seam in the walking aisle.
I am using 1/2" Baltic Birch ply over the insulation and as my finish flooring, again to limit height. The Baltic Birch is a cabinet grade product with no voids and all hardwood plys. It was only a few bucks more per sheet than crappy stuff from HD. It comes in 5x5' sheets. Today I finished fitting all the plywood pieces and have them prepped for stain and polyurethane finish.
Old 05-17-2020, 11:57 PM   #30
I like the use of furring strips where you need the support rather than some regular grid spacing for no reason.
That plywood is nice. I lucked into a 4'x8' piece of 3/4" for $25 that I used on my floor repair. It's very stiff and it's such a nice piece of wood I hate to be walking around on it.
Old 07-10-2020, 11:07 AM   #31
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Been a long while since I updated. Work on bus, work on work... Got the floor done in June. I stained the Baltic Birch with ebony stain and 4 coats of Varithane. Has a nice contrast with the cherry cabinet. I finished the area under the bed in clear so it won't be so dark in the storage area.
Old 07-10-2020, 11:12 AM   #32
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Road Worthy
I put the cabinet, pull-out sofa and bed frame back in, and a temporary counter top so we can road trip for summer. Not done by any stretch, but good to go!
Old 07-10-2020, 11:18 AM   #33
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
And away we go!
Three trips in 4 weeks. Now we're talking
Old 07-10-2020, 11:24 AM   #34
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
And away we go!
Trying to travel and stay away from people at the same time. Heading to Seattle to visit in laws though
Old 07-10-2020, 12:55 PM   #35
Engine: C7 Cat
Awesome! Great you're planning trips while doing the build. I think that's the way to keep motivated with it.
Don't let the in laws see your messages haha
Stay safe and enjoy your travels
Oscar1 is online now   Reply With Quote
Old 09-05-2020, 06:56 PM   #36
Chassis: GMC Savana 3500
Engine: 6.5L Diesel
What did you do prior to the aluminum primer to address the corrosion and what did you use to fill the bolt holes? Having a hard time finding consistent info on how best to tackle our aluminum floor.
cdgarden is offline   Reply With Quote
Old 09-08-2020, 10:50 PM   #37
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Sorry for the slow reply. I ground out pitted area, cleaned then primed. Maybe it was naive but I figured by removing the water-logged plywood, that would stop the galvanic corrosion that was occurring. I don't thing the aluminum corrodes like steel. It corrodes due to contact with dissimilar metals and water. The treated plywood has compounds that likely enhance the corrosion and when wet, and screwed into the aluminum, corrosion occurs. Remove the wet ply and the corrosion should stop.
I sealed holes by gluing down pieces of aluminum roof flashing with construction adhesive. Small holes (screw holes) I just sealed with a dab of caulk.
Old 09-09-2020, 07:46 PM   #38
Engine: 6.5L Diesel
Thanks for getting back to me. Following your build has been great info. Appreciate it.
Old 09-23-2020, 05:02 PM   #39
dzl_'s Avatar
Every. Damn. Time. I look at this bus, I get sad I missed out on the Sonoma Auction.
Great price! Perfect year, they look super well maintained, and I love the look of the Girardin Microbirds.
I'm excited to see how your build develops, looking good so far.
Are you serious/correct that the interior height is 7 feet 3 inches as stated in the original post? That is awesome!
What is the usable interior length and width?
dzl_ is offline   Reply With Quote
Old 09-24-2020, 07:59 PM   #40
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Hi dzl_
Don't worry, you'll find one.
About now I'm looking forward to seeing how it develops too. Got to get back to it. To busy all summer. I hope to pull out the ceiling soon to allow installation of Solar, vent fan and insulation.
Sorry on the typo- it is actually 6'3 high. That would have been too good!
Width is 6' 2" x 14' behind the driver.
