09-10-2018, 03:53 PM
#261
I use this in the bus, easy to store, hang up on wall or? Rocks.
Don, Mary and Spooky the cat.
09-10-2018, 05:35 PM
#262
Originally Posted by Brewerbob
Pretty sure a block that large will send the blades beyond eyeball depth.
Use a cheese slicer and slice off what you need if the whole block is overkill (pun intended). I can loan.......... ah, give you some.
09-10-2018, 06:46 PM
#263
Engine: gasser probably
09-10-2018, 09:15 PM
#264
P_ersonal love is for the squirrel cage units. Mas air!
09-11-2018, 07:42 AM
#265
HVAC companies... Old furnace blowers... weld a couple legs on.. most are all 110 volt.. put on a cord and instant fan... alot of times all this ends up stacked behind HVAC companies after they do tear outs of old systems..
I would assume they keep those locked up just for the scrap prices.
09-11-2018, 08:56 AM
#266
At least around me I usually see the old furnaces in a big pile behind the buildings.. blowers often still in them. The condensor unitsans A cools are usually not there.. I think they are more concerned with the copper coils than they are with a little copper in a 1/2 horse fan motor.
09-11-2018, 09:48 AM
#267
Chris when will you be in FL again?
09-11-2018, 07:03 PM
#268
im in savannah right now.. as we speak im plotting whether to go south to FL or attempt to make it to ohio without getting deluged in traffic escaping the hurricane...
im in my car, couldnt bring a bus to savannah jobsite.. nowhere to park it
-Chris
09-12-2018, 12:06 PM
#269
Hey Charlie,
Stupid question... can you spray Ospho? Once I get the new sheet metal up, I want to ospho it and it would be a metric shlt-ton easier to spray than roll it.
09-12-2018, 12:10 PM
#270
Originally Posted by Ospho Directions
Spray equipment should be flushed out with water after using.
I think I answered my own question.
09-12-2018, 12:47 PM
#271
Spray is the easiest application.
09-12-2018, 01:07 PM
#272
I like easy. Sometimes I even like sleazy. But that's a different story.
Now go answer my other thread (to be uploaded shortly).
09-12-2018, 01:26 PM
#273
Hey Charlie,
Yes I keep a spray bottle full for various jobs. Makes application super easy.
On a floor its easy just to dump some and mop/sweep/spread it around.
09-12-2018, 01:40 PM
#274
I meant paint sprayer not spritzer or whatever. Hopefully the sides of my bus stay vertical. Hurricane should miss here completely.
09-12-2018, 01:43 PM
#275
That will work also, wear a mask.
09-12-2018, 02:04 PM
#276
You could go all out and use a paint sprayer.
but a $10 pump sprayer from HF will do the same thing without all the cleaning up when you're done. I use an old windex bottle and find that to be sufficient.
It'll spray out of anything, though.
09-12-2018, 02:05 PM
#277
That PPE I already have. Used it while painting and xleneing. Gloves for the xyleneing would have been nice. The latex ones don't hold up so well (read as about 2 minutes before they are completely useless).
09-12-2018, 02:17 PM
#278
Already have paint sprayer. Don't know where my bug sprayer went off to. Not sure where the spritzer top went even.
09-12-2018, 03:17 PM
#279
When I was doing my floor I was pouring some out (for my homies who couldn't be here) and spreading it around with a big bristle brush.
Now I use a plastic spray bottle. I just redid my battery tray, I should post some pictures of that in my thread.
09-12-2018, 04:37 PM
#280
Nice! I ospho and repaint every battery tray I come across!
