01-06-2021, 02:59 PM
#821
Originally Posted by Ronnie
Most states up here and california shut down all businesses considered non essential. Tesla was shut down for a bit even. Pennslyvania actually sent enforcement to each business to make sure they were closed, $5000 fine if caught open. So a lot of people stayed home because no business to run. We(at the railroad) made letters for employees stating they were essential, and only for the ones we had to have.
Must say that is a bummer to have sold what they do not have though. Not good stock management.
They responded with my request to replace it with something similar with "We dont know the specs". LOL
01-06-2021, 05:28 PM
#822
Engine: C7 Cat
Sounds like a sh*tty internet reseller or outright scam. Hope you don’t get burned.
01-06-2021, 06:37 PM
#823
I used paypal. Worst case scenario I get my money back. I'm trying to get them to send me ANYthing comparable but I don't think they give a crap.
its this site-
https://www.adventurerv.net/
01-06-2021, 08:36 PM
#824
Engine: 345 international V-8
I have ordered lots of stuff through them, no problems.
01-06-2021, 08:38 PM
#825
Try getting an ac unit or a decent answer/resolution from them.
Good to know that they DO in fact ship people products at times, though. lol
01-07-2021, 10:01 AM
#826
They emailed me back this morning. They said they can have one in tomorrow in white. I'd only ordered the black one cause it was $20 cheaper. I said "send it please!". LOL why wouldn't they just offer that to begin with?
01-07-2021, 02:47 PM
#827
Coachwork: Crown by Carpenter
Rated Cap: 16
Good News!! Glad to hear!
Still frustrating when you either get the run-around or have to deal with folks who are supposed to be knowledgeable but aren't!
01-07-2021, 03:04 PM
#828
They're sending the same unit I'd ordered but in white. Said it will ship out tomorrow.
like who really cares about the color of the plastic shroud?
01-07-2021, 03:08 PM
#829
I've got two 16ga panels prepped and ready to install the ac. The outside panel will just perfectly fit into the spot where the hatch was and has a 14" square already cut in center.
I've got another for the inside cut the same. But 16ga is way overkill. IDK how easily this is going to mount, but once this is all installed it should be rock solid.
Will run some romex down through the ceiling to the conduit and down to the outside bottom corner of the bus.
01-07-2021, 07:05 PM
#830
Engine: TE 444
Rated Cap: 12
you will have to cut wood blocks to fit the gap between the inner and outer panels, the AC unit mounts with a clamp arrangement that will try to pull the 2 panels together
01-07-2021, 07:23 PM
#831
will do that!
01-07-2021, 09:14 PM
#832
I welded square tubing to make a frame for mine, and attached to the ribs.
01-08-2021, 01:43 AM
#833
I did the same thing.
This shot is oriented from the front to the rear of the bus
The piece in the foreground that is arched on top bolts to the hat channel nestled along the skin of the roof ... same in the back.
01-08-2021, 06:05 AM
#834
Attachment 52782
Nice.
01-08-2021, 08:03 AM
#835
I started a FB group called "Roll Your Own".
Figured its easier to share stuff and plan get-togethers over on FB.
Here's the link if anyone wants to join-
https://www.facebook.com/groups/156115572683980
01-08-2021, 09:48 AM
#836
I've been thinking what would the best coating be for the galvanized floors once we get them fully prepped.
Epoxy coatings designed for steel floors!
https://www.zoro.com/rust-oleum-9100...02/i/G0839754/
01-10-2021, 10:23 AM
#837
wow! They sent the white unit two days ago! Will be here SOON!
01-10-2021, 01:28 PM
#838
Self etching primer for the steel, some genuine 3m masking tape, and a few tubes of seam sealer ordered.
Starting to feel the excitement of getting this ac project underway.
01-13-2021, 01:34 PM
#839
Fedex just dropped off the AC unit! They sent the inside unit at the same time so I got em both.
Now just waiting on some primer, seam sealer, and paint to proceed.
01-13-2021, 02:36 PM
#840
Kool! Pun intended. Losa pics please. Jack
