Old 09-10-2018, 02:53 PM   #261
2kool4skool's Avatar
I use this in the bus, easy to store, hang up on wall or? Rocks.
Don, Mary and Spooky the cat.
Old 09-10-2018, 04:35 PM   #262
Originally Posted by Brewerbob View Post
Pretty sure a block that large will send the blades beyond eyeball depth.
Use a cheese slicer and slice off what you need if the whole block is overkill (pun intended). I can loan.......... ah, give you some.
Old 09-10-2018, 05:46 PM   #263
oricha1984's Avatar
Engine: gasser probably
Here at harbor freightClick image for larger version
oricha1984 is offline   Reply With Quote
Old 09-10-2018, 08:15 PM   #264
P_ersonal love is for the squirrel cage units. Mas air!
Old 09-11-2018, 06:42 AM   #265
Brewerbob's Avatar
HVAC companies... Old furnace blowers... weld a couple legs on.. most are all 110 volt.. put on a cord and instant fan... alot of times all this ends up stacked behind HVAC companies after they do tear outs of old systems..
I would assume they keep those locked up just for the scrap prices.
Old 09-11-2018, 07:56 AM   #266
At least around me I usually see the old furnaces in a big pile behind the buildings.. blowers often still in them. The condensor unitsans A cools are usually not there.. I think they are more concerned with the copper coils than they are with a little copper in a 1/2 horse fan motor.
Old 09-11-2018, 08:48 AM   #267
Chris when will you be in FL again?
Old 09-11-2018, 06:03 PM   #268
im in savannah right now.. as we speak im plotting whether to go south to FL or attempt to make it to ohio without getting deluged in traffic escaping the hurricane...
im in my car, couldnt bring a bus to savannah jobsite.. nowhere to park it
-Chris
Old 09-12-2018, 11:06 AM   #269
Brewerbob's Avatar
Hey Charlie,
Stupid question... can you spray Ospho? Once I get the new sheet metal up, I want to ospho it and it would be a metric shlt-ton easier to spray than roll it.
Old 09-12-2018, 11:10 AM   #270
Brewerbob's Avatar
Originally Posted by Ospho Directions
Spray equipment should be flushed out with water after using.
I think I answered my own question.
Old 09-12-2018, 11:47 AM   #271
Spray is the easiest application.
Old 09-12-2018, 12:07 PM   #272
Brewerbob's Avatar
I like easy. Sometimes I even like sleazy. But that's a different story.
Now go answer my other thread (to be uploaded shortly).
Old 09-12-2018, 12:26 PM   #273
Hey Charlie,
Yes I keep a spray bottle full for various jobs. Makes application super easy.
On a floor its easy just to dump some and mop/sweep/spread it around.
Old 09-12-2018, 12:40 PM   #274
Brewerbob's Avatar
I meant paint sprayer not spritzer or whatever. Hopefully the sides of my bus stay vertical. Hurricane should miss here completely.
Old 09-12-2018, 12:43 PM   #275
That will work also, wear a mask.
Old 09-12-2018, 01:04 PM   #276
You could go all out and use a paint sprayer.
but a $10 pump sprayer from HF will do the same thing without all the cleaning up when you're done. I use an old windex bottle and find that to be sufficient.
It'll spray out of anything, though.
Old 09-12-2018, 01:05 PM   #277
Brewerbob's Avatar
That PPE I already have. Used it while painting and xleneing. Gloves for the xyleneing would have been nice. The latex ones don't hold up so well (read as about 2 minutes before they are completely useless).
Old 09-12-2018, 01:17 PM   #278
Brewerbob's Avatar
Already have paint sprayer. Don't know where my bug sprayer went off to. Not sure where the spritzer top went even.
Old 09-12-2018, 02:17 PM   #279
brokedown's Avatar
When I was doing my floor I was pouring some out (for my homies who couldn't be here) and spreading it around with a big bristle brush.
Now I use a plastic spray bottle. I just redid my battery tray, I should post some pictures of that in my thread.
Old 09-12-2018, 03:37 PM   #280
Nice! I ospho and repaint every battery tray I come across!
