Old 03-14-2020, 09:34 PM   #1
Coachwork: Collins
Chassis: Chevy 3500
Engine: 5.7
Rated Cap: 9+4
Side panel removal 5 window Collins
Do these need to be cut below the window line to removal the side panels? I started removing rivets and pulled the window and it looks like the inside skin is folded over the exterior skin.
Also does the chair rail get removed or do i stop there
BUS2SLO is offline   Reply With Quote
Old 03-14-2020, 11:45 PM   #2
Coachwork: Self
Engine: 7.3 L powerstroke diesel
Yours looks a little bit different from ours but for the wall panels we had to grind rivets then remove windows then remove horizontal ribs on the exterior in order to pry the panel out of the space between exterior and interior walls. Not sure if that makes sense but it was way more complicated than we initially thought.
As for those seat tracks, we removed ours to expose the metal subfloor to properly assess rust. In order to remove those we had to grind off the heads of the bolts using a diamond wheel on angle grnder and then punched out the rest of the bolt. Went through 3 wheels but finally got them up.
Best of luck!
Kerboo_n_wilnil is offline   Reply With Quote
