RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-19-2020, 02:33 PM   #1
Step Tread Removal
Does anyone know how to remove the step tread from the passenger entry? I canít get it to budge.
File Type: jpeg C1921B3C-161F-4A4B-A784-3688D2B6F19A.jpeg (100.4 KB, 6 views)
peaceofanotherkind is offline   Reply With Quote
Old 04-19-2020, 11:22 PM   #2
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Mine had screws in the white part on the front edge. They were glued down as well. It had a sheet metal backing to it and was a pain to get out. I started with a flat nail bar and hammer to get the edge up. Then I used a 4' pry/wrecking bar to pry up, slide under, pry up and slide under pry, etc... It bent the stair treads up but I got them off. Hope this helps and good luck!!
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
Frochevy is offline   Reply With Quote
Old 04-20-2020, 07:40 PM   #3
sepudo's Avatar
Chassis: fs65
Engine: 7.2 catapillar 3126
Rated Cap: 41 students
Just removed mine yesterday to clean and inspect under them.
@drivingdharma
sepudo is offline   Reply With Quote
Old 04-21-2020, 03:04 AM   #4
I believe some are just screwed in and some are glued. On our Thomas, it was just totally rusted in screws that needed a little help to remove. Once the screw heads were gone (or the screws removed), the steps came up easily.
Old 04-21-2020, 09:39 AM   #5
Wow. That looks amazing and gives me hope for ours. Thanks for sharing!
Old 04-21-2020, 09:41 AM   #6
We did get the screws out, though it took a lot due to the rust. I was expecting them to come off relatively easily after that, but itís so stuck, I canít even imagine how much glue they used.
Old 04-21-2020, 09:42 AM   #7
Just screwed in with 6 screws each Attachment 43548
entry, remove, stair, step, tread
