08-18-2016, 09:07 PM
#21
Engine: t444e
Lost power at work today so I left at 6, got home, played with my giant toddler(over 3ft@21mo) put him to bed then did some bus time. All driver side low panels are cut except the rivets behind the emergeny window frame, couldn't run my impact with the boy sleeping. Cut about 1/3 of a ceiling panel's rivets too.
Used my grandfather's 1970s ish Great Falls grinder with a 7" disc, that thing is a beast.
Photos in the morning after I finish tearing the panels.
08-19-2016, 09:13 AM
#22
Why? It sounds like the young fella is big enough to run the grinder.
08-19-2016, 03:40 PM
#23
Engine: t444e
He lifts mulk jugs one handed.
08-20-2016, 06:56 AM
#24
Engine: t444e
08-20-2016, 07:42 AM
#25
Interesting- looks like bluebird uses the tar (asphalteum to be specific) on some buses too. I've seen under the interior panels of an 88 BB and it didn't have any tar. I wonder if that was an option?
08-20-2016, 08:52 AM
#26
maybe it was a year thing? or geographic? ive found there are a lot of things done to busses based on geoprgraphic locations..
Like certain states required the driver and door side windows of busses made after a certain date to have double pane windows to elp with snow and ice...
08-20-2016, 09:01 AM
#27
Engine: t444e
I think it may have to do with high humidity, the insude panels dont seem to sweat much
08-20-2016, 09:32 AM
#28
Mine were sweating UNDER the tar.
08-20-2016, 12:32 PM
#29
Engine: t444e
That's what happens when you live in a swamp.
08-20-2016, 12:42 PM
#30
Engine: t444e
2 more roof panels down and that front panel that covers the nose lights. Did anyone put that panels back up? seems like a good base for mounting stuff. Supposedly my seats and other scrap are getting hauled off today, if he bails I'm just going to flag down one of the numerous scrappers in town. I'm holding onto 3 seats for now, one for a friend to mount in his work van and 2 as a temp until I can make it to LKQ and get the rear benches out of an early 2000s Escalade, with built in seatbelts.
My bench seats have seatbelts so if anyone in Houstonish wants one speak now or forever hold your peace.
Got the cover off my A/C so I have an idea what I'm working with, its got 3 blowers so I may duct one or two to the front of the bus for OTR A/C.
08-20-2016, 05:25 PM
#31
Great progress Chili. Today's heat was a bi*ch. I got some done on mine as well and will post pics.
08-20-2016, 09:03 PM
#32
Engine: t444e
Nah man, it was pleasant today, you spend too much time in the a/c ;) . We got woken up at 6:30am for the Watermelon walk for the fallen, Youngster loved seeing some planes in formation, sky divers, all kinds of goodies. FIL came by and gave the bus a thumbsup on the mechanical side, also showed me how to take down my a/c to get my last 2 roof panels out.
08-20-2016, 10:24 PM
#33
if you are keeping that Air unit, clean it up wile you have it apart.. te drain lines love to clog on those as do the coils... and be careful wit htose refrigerant lines... the rubber will crack or kink if you leave it in a stressed position too long... im assuming you supported it someow...
you COULD move that evaporator to the front of the bus and re-pipe it in if you want it for road A/C rather tan attempted to duct it...
those lines are easy to make...
08-21-2016, 06:27 AM
#34
You are correct, that a/c will spoil a person. I just need a good fan to keep the air moving.
08-21-2016, 06:33 AM
#35
I did take the front panel off and the fins were pretty clogged. I saw on youtube a while back about someone cleaning their rooftop a/c fins with a spay bottle of cleaner/dissolver. Is there anything special about the formula or will any cleaner/degreaser work like 409 or something?
That a/c unit is just temporary while I do the demo for the next 2 months. After then it will start to cool down here in Houston. By the time next summer rolls around it'll be fully insulated, new insulating paint on the roof, and I may even pay for a covered spot so the heat won't be as much of a factor.
08-21-2016, 07:29 AM
#36
I didn't know they had swamps in KY.
08-21-2016, 08:07 AM
#37
depending on the coils you have to be careful with certain acid cleaners as they can eat the solder that was used to make the coils.. alot of time of the dirt is topical... you can get it wet then use a coil brush and the glop will just come off...
you can use a nice no rinse cleaner.. you want no rinse as its tough to hose inside of the bus around the A/C unit.
https://www.amazon.com/Nu-Calgon-417...SIN=B00DM8KQ3I
you will also want to clean the coils underneath the bus too as those get very dirty too (im talking coach A/C)..
even insulated heat will still be a factor.. you will want air-conditioning esp for driving as school busses put off a ton of engine heat.. RE busses dont have that issue but conventionals and front engine busses tend to have "hot-seat" in the driver position...
08-21-2016, 09:00 AM
#38
Engine: t444e
Take down should be pretty easy, its got quick connects on all the lines from up front, handful of wires that I will be taking pictures of. It's supported with 4 pieces of all thread so I'm thinking put my scaffold under it, shimmy up to it with some block then disco and gun the nuts off. We shall see.
I like the unit being at the back as it's (more or less) out of the way so I think ducting will be my best option.
Sorry CB, it says Florida on the left.
08-21-2016, 09:11 AM
#39
be sure to recover the freon first!!!! dont just yank the lines... freon can and will destroy eyes and skin ifyou arent careful...
then tape off the lines to keep dirt out... blue tape works fine..
when you re-install it, replace the receiver / drier (near the condenser usually).. evacuate to a vacuum and recharge... evacuating is important if you want it to cool most effectively...
your air-conditioner can still give you many more years of service if you treat it right.
08-21-2016, 10:15 AM
#40
Engine: t444e
Don't worry, we're earth friendly down here FIL will be recovering and then handling the recharge, He's a major gearhead. Should have stated that.
