Old 05-27-2019, 08:39 PM   #281
plfking's Avatar
Rated Cap: 34
Found out why I had a few leaks from the flashers. The back of the assembly has 'legs' where the screws hold the assembly to the body, and these legs leave a 1/8" gap all around the circumference....the water just runs into the holes in the endcaps and into that foam inner-seal. You'd think there would be a gasket, at the least, to prevent that, but not so.
I wanted to keep the school bus look, but wanted the lenses to be more noticeable, so I took them apart and gave them a mineral spirit scrubbing. To brighten them, I left the base off of the lenses and painted my backing tin white to help reflect more light. They turned out much brighter than my brake and turn signal lenses, so I'll have to go back and do them as well.
Don
The Busted Flush
Old 05-27-2019, 09:31 PM   #282
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
What lights do you have up top on the front? LEDs?
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
Frochevy is offline   Reply With Quote
Old 05-27-2019, 11:23 PM   #283
HazMatt's Avatar
Chassis: IH 3800, 8 window
Sure do look like it.
Old 05-28-2019, 10:44 AM   #284
plfking's Avatar
Rated Cap: 34
Nah.....they DO look like lights, but that's just the tin backer plates, painted white, before I put the lenses back on. Still undecided if I want to put floodlights up there at a later date, but for now I wanted to get the leaks sealed before finishing the interior of the endcaps.
Don
The Busted Flush
Old 05-28-2019, 11:57 AM   #285
HazMatt's Avatar
Good work!
Old 05-28-2019, 12:01 PM   #286
Frochevy's Avatar
Chassis: Collins
I'm needing to do the same thing you are doing. I was thinking about going with clear lens or installing some round flush mount LED lights in those places.
Old 05-28-2019, 09:26 PM   #287
plfking's Avatar
Rated Cap: 34
At one time I considered plexiglass over the holes, to allow more light in that chronically dark area of most buses, but then decided in favor of cutting my transom windows, to allow even more light PLUS move air through the bus.
And given all the discussions I've read on here about whether or not high-mounted white lights are even legal without some cover over them, I think I'm just going to mount additional lighting in my front bumper cut-outs.
Don
The Busted Flush
Old 06-16-2019, 05:24 PM   #288
plfking's Avatar
Rated Cap: 34
Had originally built my generator door to accommodate a HF Predator 2000, but changing horses mid-stream......so I had to cut out some skin and build a wider door. I did color match the wood a little better this go-round.
And got my windows sussed out. Spent a LOT of time pondering, and multiple mock-ups, trying to figure out how to achieve one-handed operation. The size of these latches are overkill to be sure, but I didn't trust the smaller ones to hold up. I think these will outlive me. And one-handed op rules!
Don
The Busted Flush
Old 06-16-2019, 08:44 PM   #289
Frochevy's Avatar
Chassis: Collins
Will you operate the generator in there or just haul it in that location?
Old 06-16-2019, 09:00 PM   #290
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Where did you purchase those red handled window closers, Don?
Old 06-17-2019, 06:38 PM   #291
plfking's Avatar
Rated Cap: 34
If I can insulate well enough I'll run it there, but I'm *planning* a pull-out tray with support legs, with an attached hood for sound deflection.
Don
The Busted Flush
Old 06-17-2019, 06:52 PM   #292
plfking's Avatar
Rated Cap: 34
Got 'em from these folks....very fast and free shipping.
Great deals from fastlaneusastore | eBay stores
These are more for a fence gate or trailer tailgate application, but, like I mentioned, the others I looked at weren't robust enough to suit me.
Don
The Busted Flush
Old 06-17-2019, 07:01 PM   #293
Thanks Don. I just ordered 2 in S/S. Perfect for the inner door latching I needed!
Old 06-17-2019, 07:08 PM   #294
Most all onboard factory RV gens use a directed exhaust outlet, directing spent fuel emissions away from the vehicle and not just underneath/toward the ground.
There is a potential for serious consequences if exhaust can migrate into the sleeping areas.
Something more to think about!
Old 06-17-2019, 07:49 PM   #295
plfking's Avatar
Rated Cap: 34
Most definitely!
And glad to help.
Don
The Busted Flush
Old 06-23-2019, 05:26 PM   #296
plfking's Avatar
Rated Cap: 34
I'm 6'1" with a 34" inseam.....not sure of the size of the 'average' bus driver, but I prefer to drive with my arms extended, so I moved the seat pedestal back a few inches......which left me unable to fully depress the clutch.....so I built up my pedals. Reminded me of my grandpa, who did the same on his farm tractors when I was 10 or 11 so I could drive them in the fields. I still had to stand up on the brakes to get them stopped.
Also made some head- and foot-bolsters to fill up the difference between my 75" mattress and the 90" wall-to-wall span. Decided to leave the tops loose for storage underneath....not sure what I'll keep there, but it's a small bus, so I'm sure something will migrate there.
And started on my bathroom innards. That's either my bucket or my new coffee cup.....haven't decided yet.
Don
The Busted Flush
Old 06-23-2019, 05:32 PM   #297
Looks good, with ingenuity on the pedal extensions!
Just don't make it your coffee cup after using it as your "bucket"...
Old 07-05-2019, 06:19 PM   #298
plfking's Avatar
Rated Cap: 34
My new $3 gear shift knob.
My window spring latch handles were riding on my shelf, so I added some hardwood blocks to raise them a little.
And started on my propane cage....will probably be a plywood box with a wire bottom. Thought about a 2"x 3" frame with wire bottom and sides, but slightly concerned about rocks getting thrown up against my tanks. I don't look forward to cutting/grinding off that floor rib.....last time I ended up eating a lot of sparks because of the close quarters under there. Anyone got an easier method? I would try my air chisel, but I already sold my compressor.
Don
The Busted Flush
Old 07-05-2019, 07:55 PM   #299
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Maybe cut the rib with a reciprocating saw
Nick
Old 07-07-2019, 09:51 AM   #300
TheHubbardBus's Avatar
I'd think an OA torch would make pretty short work of that. Course then you'd have to be dodging slag rather than sparks. Still, if you can get a good angle on it...
