Old 07-07-2019, 05:35 PM   #301
plfking's Avatar
Rated Cap: 34
I tried the saw when I did my steps last year, but there's not enough room under there......and nobody wants to see me with an OA torch in-hand. I finally got it out using a cutting disc, grinding disc, hammer, crowbar, cold chisel, hand sledge, magical incantations and cuss words. And I kicked it a few times when I finally had it on the ground.
Got my cage built. All the wood joints will bolt together, and then the whole cage will be bolted to the frame, floor rib, skirt and skirt bracket......not trusting any of this to screws. I've already disassembled and sanded....I'll put 3 coats of paint and 3 coats of urethane on everything this week, then re-assemble it next weekend. The back plate is wider to allow me to use 3 existing holes in the frame, and the cut-out on the right will be to access a propane manifold mounted to the side of my stepwell.
Don
The Busted Flush
Old 07-07-2019, 07:56 PM   #302
TheHubbardBus's Avatar
haha... thought you were kidding till I saw the picture, all the tool marks, and your foot Looks great!
So how do you access the tank? Does is swing down, slide out, etc?
Old 07-07-2019, 08:42 PM   #303
plfking's Avatar
Rated Cap: 34
That thing cut me twice, and almost set my hair on fire......kicking it felt quite cathartic.
The tanks (have room for two) slide in horizontally, then rotate upright. Sliding them in vertically would have required cutting out the bottom rub rail, and I didn't want to do that....I like that clean line across the bottom. The top of the door cut-out is even with the floor.
Don
The Busted Flush
Old 07-08-2019, 09:33 PM   #304
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Looking good!
I'm late for the response... But I would have done what you did for the most part. What worked well for me In a Situation like that is 4.5 grinder with cut off wheel as deep as I can go. (Direct your Sparks in a manner not to blow back in your face) then use a sawzall with 6" or greater bi-metal blade on it and cut through the deeper ribs the cut off wheel won't reach...
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
Frochevy is offline   Reply With Quote
Old 07-08-2019, 09:35 PM   #305
Frochevy's Avatar
Chassis: Collins
I may have been mistaken... Were you removing the rib from underneath and not the floor itself also?
Old 07-09-2019, 05:18 PM   #306
plfking's Avatar
Rated Cap: 34
Yes.....just one rib underneath, and left the floor alone (...I would have said "left the floor intact", but the cut-off disc got away from me slightly at one point...).
I *guess* 90 minutes of hell to save 2.5" of ground clearance was worth it.
Don
The Busted Flush
Old 07-09-2019, 05:19 PM   #307
Frochevy's Avatar
Chassis: Collins
Well the main thing is it's done and you won't have to make that same cut again. That's what I felt like after I got all of my seats out... Lol
Old 07-09-2019, 05:24 PM   #308
plfking's Avatar
Rated Cap: 34
Haha! That's what I kept telling myself the whole time...'you only gotta do this once....you only gotta do this once"...
Don
The Busted Flush
Old 07-13-2019, 06:14 PM   #309
plfking's Avatar
Rated Cap: 34
Bolt City.......3/8x16 s everywhere. Overbuilt like a lot of stuff on my bus, but at least I won't be worried about it while bouncing about the countryside. I'll build the door and finish the trim and paint early tomorrow.....95 degrees is too hot, especially since I'm not under any time constraints.
And got into an argument with a 1" diameter drill bit at work Wednesday.....I lost.
Don
The Busted Flush
Old 07-14-2019, 01:07 PM   #310
Frochevy's Avatar
Chassis: Collins
Ouch!! That looks like it hurt!!!
Propane locker is looking good tho!!
Old 07-14-2019, 01:25 PM   #311
HazMatt's Avatar
Chassis: IH 3800, 8 window
When I screw myself, it's typically from poorly considered life-choices.
Tho sometimes power tools have played their part...
Old 07-14-2019, 08:37 PM   #312
plfking's Avatar
Rated Cap: 34
It looks worse than it feels....any strawberry I ever got from sliding into second hurt a lot worse.
Propane storage is done. Easy to slide the tanks in and turn upright, and have room for a pair. I'll add some eyehooks and bungees to keep them from rattling around in there. And got all the ground clearance that I could.
I hope I'm done building doors.
Don
The Busted Flush
Old 07-14-2019, 08:41 PM   #313
Might want to invest in a builders square.
Old 07-15-2019, 07:26 AM   #314
plfking's Avatar
Rated Cap: 34
Might want to invest in a non-douchebag personality.
I don't post PMs from friends, which is why I have no qualms about sharing yours....
You'll notice I have been absent from your build thread. Open your mouth once more on a post I've made that doesn't concern you and I will personally make it my mission to comment on every stupid mod you do to your bus.
Surprised it took you a year to act on your threat, but not surprised at the lameness of your insult.
Don
The Busted Flush
Old 07-16-2019, 07:11 PM   #315
Looks great, Don! In the bottom pic it looks like it came that way. You can't even tell it's an addition, if not for the color & the trim.
The propane bay, I mean. Not your hand
Old 07-16-2019, 07:35 PM   #316
I have found that feeding a troll only increases it's appetite.
Don't feed the troll and evenuay it will find a new home. But..... It's hard not to sometimes
Old 07-17-2019, 07:45 PM   #317
plfking's Avatar
Rated Cap: 34
May have been karma paying me back for kicking that floor rib.
Don
The Busted Flush
Old 07-17-2019, 07:52 PM   #318
HazMatt's Avatar
Don't it suck when karma runs over your dogma..?
Old 07-17-2019, 08:06 PM   #319
plfking's Avatar
Rated Cap: 34
I'm a 'live and let live' type, until it conflicts with my 'do unto others as they do unto you' credo.
Don
The Busted Flush
Old 08-04-2019, 08:03 PM   #320
plfking's Avatar
Rated Cap: 34
Been running awning ideas through my head for awhile, and today was the day. Thought about using a roller, but was leery of it rubbing against my window awnings on the way up and wearing down too quickly, so I just roll it up by hand, put the clamps on it, set it on top of my window awnings, then climb up and roll it up the rest of the way. The storage boxes are only 4" tall, so very low-profile.
Was surprised at how well it all fit together.....figured I'd have to trim my support poles down a little, but the low side is exactly 6' off the ground, so I barely have to duck. I'll let the lumber air out this week, then urethane next weekend, as well as paint my support poles red and yellow 'barber-pole' style.....which means I'll only walk into them half the time. And with the free end of the tarp sandwiched between 2 pcs of 5/8" dimension stock, it doesn't want to move side-to-side, which eliminates having to tie it off on each side. All in all, very pleased........and figure I can replace it every single year for 20 years for what a new RV awning would have cost.
I'll also make a small 6'x6' awning for the deck at some future point in time.
Don
The Busted Flush
