12-11-2017, 08:51 PM
#21
Chassis: Saf-T-Liner MVP ER
I took my student mirror and visor out. If I'm looking in that mirror while I'm driving it's not good. The side mirrors are what I'm accustomed to using.
There don't seem to be a whole lot of other uses for those student mirrors, but I'm thinking of putting it on my tractor for a wider field of view while backing.
I want to keep as much "School Bus" character as I can.
I have a wife and daughters, I'm thinking it would make a great bathroom mirror with a few lights around it.
12-11-2017, 09:24 PM
#22
That was the same use I came up with for the student mirror, other than on the tractor as a spectacular backup mirror. For a bathroom I thought it could mount vertically in a corner quite easily for a dressing mirror without taking up much space.
I didn't bother building a bathroom so I don't have quite as many corners to put the mirror in as some might have.
Robin
Nobody's Business
12-13-2017, 10:37 PM
#23
Rated Cap: 34
Definitely the same here.
Refurbished the first item. $25 for new mirror glass, and reused the metal frame and backplate, gasket, and brackets from visor. A little Krylon "Hammered Finish" spray I had floating around, and it looks great. Thing feels like it weighs 10 pounds.....no cheap plastic here.
The helmet sticker elevates it from 'ordinary' to 'an extraordinary expression of refined taste and class'.
Don
12-13-2017, 11:14 PM
#24
It sounds like you need the champagne of beers.
Robin
Nobody's Business
12-14-2017, 08:04 AM
#25
Congrats. As shorties go, that is the size everyone wants. That's the engine everyone, who knows, wants.
Indeed! This is exactly what I want. (Hand ME one of your beers so I can cry in it.) Sob sob
Sent from my SM-N950U using Tapatalk
12-14-2017, 10:38 AM
#26
Rated Cap: 34
They're out there. You just have to look at every site you can think of and hit the nationwide CL every day or two.....I got lucky in that mine was listed late on a Sunday night and I saw it about two hours later, and I called the guy early Monday a.m.
Patience is the key. Can't tell you how many times I almost pulled the trigger on something less than I wanted out of sheer frustration. And like everyone here says....another bus comes up for sale every day.
Don
12-14-2017, 10:46 AM
#27
Don
Thank you, Don. I MUST be more diligent!
12-16-2017, 11:01 PM
#28
Rated Cap: 34
VERY productive day out at the bus today. All the seats and dividers are out.....filthy job, but I was rewarded with 35 cents and some kind of token. If that happens 10,857.142 more times, I got my bus for free.
Even though it was nasty, boring work, I was pumped by the fact I was getting it done, and getting closer to my vision for this mofo.
TIP -- when removing seats, start at the front and work your way back.....lots more working room.
And I don't know why, but I find myself constantly moving around with my head bent forward, even though I have a good 2.5" - 3" of head clearance. I hope that goes away after awhile.....my head doesn't touch the ceiling until I get about 12" from the windows.
Tomorrow will be spent seperating the foam and vinyl from the seat frames in preparation for a trip to the metal recycler. Next weekend will be stripping the linoleum and getting a look at the floor, although it's looked good in the 4 test areas I've examined. This bus doesn't have a plywood subfloor, so it may go quickly.
Ain't it purty?
Don
12-17-2017, 07:09 PM
#29
Rated Cap: 34
Seats are deconstructed. Anyone need any foam?
This was the worst of the floor rust in the 4 test areas......60 seconds with a putty knife and I had shiny metal. I think my wire wheel will make short work of it next weekend. Just have my fingers crossed that the rest of the floor is no worse.
And tried out my $13 heat gun from HF on the back decals.....worked great! I think I'll buy 3 more and use them for my secondary heating option.
Don
12-17-2017, 07:16 PM
#30
Man, its coming along nicely!
I'm so glad you scored that shorty, man.
12-17-2017, 07:43 PM
#31
Rated Cap: 34
I don't think I've stopped smiling since I got it home.
My face hurts.
Don
12-17-2017, 07:51 PM
#32
My face hurts.
Don
Even with all the little and not so little issues mine has, I'm feeling the same way.
12-24-2017, 07:50 PM
#33
Rated Cap: 34
Another productive, nasty, smelly, lucrative weekend out at the bus.
I feel I've paid off the balance owed on my Skoolie Club Initiation Fees......6 hours of grinding rust. And I found where the 'school bus' smell comes from......burning powdered rust! (..or maybe the burning rust just releases the school bus smell....).
Linoleum peeled right off in 8 big pieces....all done in 10 minutes. Same with the rubber on the wheelwells. Wire-wheeling the rust took considerably longer, but for the most part is done.....I still have a couple of spots I want to hit with a grinding wheel.
Gluing pennies down tomorrow, then next weekend I'll remove the seat, doghouse, shifter boot, etc. and wire-wheel that area, then ospho and paint the entire floor, weather permitting....it's only supposed to be in the 30s for the next 10 days or so.
This floor, and the wheelwells, are SOLID with a capital S. I can't find a soft or spongy place anywhere, and the only holes are of the drilled variety. Very pumped about that.
And the 'lucrative' part? Found another quarter.
Hope y'all have a great Christmas, or Holiday, or whatever you wish to call it.
Don
(...I must be getting old.....my pictures used to be in better focus...).
12-24-2017, 07:56 PM
#34
Mmmmm...nice!
12-24-2017, 08:02 PM
#35
Originally Posted by Tango
Mmmmm...nice!
Concur.
A good job, well done!
12-24-2017, 09:24 PM
#36
If you had a coach, you'd have to be glueing down quarters instead of pennies.
Robin
Nobody's Business
12-30-2017, 07:37 PM
#37
Rated Cap: 34
On a dark note, not as much accomplished this weekend (so far) as hoped. As easily as the rear linoleum came up, the driver's area linoleum is a whole 'nother beast.....it is fighting me every inch of the way. If I have to take my angle grinder or blow torch to it, so be it.
On a brighter note, check out my paint.....I needed a nice bright cheery color after grinding rust all last weekend.Will add 1 more coat tomorrow or Monday.
On an additional 'brighter' note, my new LED headlights came today.....if I can feel my fingers tomorrow, they'll be installed. My heater burns me up in the bus, but doesn't warm up the great outdoors very much. It's been in the mid-30s the last 2 days, but inside the bus (just above the windows) it's around 90......and that's with both doors and 2 windows open. Maybe I don't need insulation.
Don
12-30-2017, 08:58 PM
#38
Man, this isn't fair! Now you're way ahead of me!
12-30-2017, 09:46 PM
#39
Rated Cap: 34
It's not a race......plus I haven't had the down-time you've had....I hope that changes quickly, and in a big way.
And as long as your dinette seats are in my possession, and not yours, I'll ALWAYS be a little ahead.
And if you start to catch up, I'll threaten to incinerate them.
Don
12-31-2017, 03:46 AM
#40
Don
Funny- yesterday we tore down and burned a good sized garage/shed on my friend John's property. I have a hard to find four legged seat for one occupant sitting ten feet away and it caught fire! Good thing I was gonna replace all the vinyl anyhow.
Yeah I know its not a race but I've been watching folks enjoy their buses and I can't wait to get this one of mine on the road for real!
