09-21-2019, 04:52 AM
#21
Engine: 3500 Gas
Rated Cap: 21
Webasto does make gasoline heaters. That may be an option for you.
For me.... Nothing but diesel.
I’ve never heard of these heaters till now so I will deff look into them! Thanks
-Tom
"Get Busy Living or Get Busy Dying" -MF
09-21-2019, 07:13 AM
#22
Originally Posted by TheCruxBus
Some Before and after pics of the demo. More is demoed, but it was night when I was done so I will get those for you guys once I get back out there.
Looks like you have some peeling paint on your windows. Mine were similar and I got good results by removing them and scraping off all the loose paint, taking them to the carwash for a thorough cleaning, then painting the bare metal areas with SEM self-etching primer and then oil-based enamel. I used a good-quality brush and the brush strokes are not really visible; you could spray instead but I didn't feel like masking off all 20 of my windows.
Rust on the heads of the bolts holding the seats in place is a sure way to tell that the floor will be rusty pre-demo.
09-21-2019, 07:16 AM
#23
Originally Posted by o1marc
I have a Mini-Split for heat and A/C, and also a diesel air heater. That might be a better option because if the stove isn't there when you insure, and it's the cause of an accident, they won't pay.
Do those diesel air heaters produce a noticeable diesel smell from the exhaust? Do RV parks ban their use or anything like that?
09-21-2019, 07:58 AM
#24
Engine: 3500 Gas
Rated Cap: 21
Thanks for the reply, funny actually that’s not peeing paint it’s moss or some sort of organic substance lol. It needs a good wash but will keep that in mind if I do come across paint peeing!
The bottoms of the bolts and nuts were semi rusted but the heads were fine. All in all It was about 5 hours and the only reason I needed to use a grinder was because the nuts were inaccessible due to them being right above the fuel tank. I guess this is probably a short bus problem, you guys and all your room I’m a bit envious hahah. But man a nice pneumatic impact gun would of been super helpful hahah.
09-21-2019, 11:42 AM
#25
It has an exhaust pipe that mounts outside the cabin, so no smell inside.
09-21-2019, 12:03 PM
#26
I meant does it produce a noticeable smell outside? I wouldn't want the place where I'll be staying to smell like a truck stop.
09-21-2019, 12:36 PM
#27
Chassis: TC RE
Engine: 8.3L
You would have to stand right next to the exhaust to even notice it.
GaryC
09-21-2019, 05:04 PM
#28
I doubt it's a concern, certainly nowhere near what we put out the exhaust pipe on the bus.
09-21-2019, 09:37 PM
#29
... plus, they only sip the diesel fuel.
09-21-2019, 09:51 PM
#30
They are adjustable, so if it's tuned it won't have much exhaust.
09-26-2019, 08:23 AM
#31
Hey nice bus
We recently just bought a 2003 e450 5 1/2 window and just started to demo with very similar plans we're on long Island too!!!
09-26-2019, 09:21 AM
#32
Engine: 3500 Gas
Rated Cap: 21
Originally Posted by robo808
Hey nice bus
Sweet man! My bus is in Brookhaven I live in Rockville center pm me and we can meet up some time!!
