02-22-2020, 07:29 PM
Coachwork: Ford
Chassis: E350
Engine: V10
Thin aluminum?? Flooring
Hey gang. This is my first post.
I’ve been looking around the site for a while and couldn’t come up with anything similar to my situation.
I recently purchased a 1998 Ford E Super Duty shuttle bus.
I pulled the seats out and ripped up the rubber floor. I did this because I noticed some “soft” spots while I was walking around.
After pulling up a 1/4 sheet of plywood there is a thing aluminum type metal underneath the wood.
The problem is, when I go to remove the wood, I can’t use a pry bar. When I do the pry bar goes right through this thin material.
I am not a metal expert, so I am assuming it’s aluminum. I can EASILY bend it with my hands.
Any ever deal with this? If so, how did you get the floor up without losing the metal floor and your patience.
Thank you.
02-22-2020, 07:46 PM
It's almost certainly not aluminum. Hold a magnet against it to be sure (aluminum will not attract the magnet, steel will).
Most likely it is steel and your pry bar is going through it because it is severely rusted.
02-22-2020, 08:03 PM
That was my first thought but then I realized we're talking about an E350 -- basically a 1 ton work van. It could have an aluminum box on it to save weight...
The magnet will not lie.
If it is Al -- I would look for the fasteners and remove them OR just drill the heads off -- then the plywood will come up.
02-22-2020, 08:06 PM
Coachwork: Ford
Chassis: E350
Engine: V10
No rust on it. It’s clean, very clean. I will post a photo tomorrow and try a magnet.
It just bends anytime my pry bar is applying any pressure and then a hole rips through it.
Live your life full of love
02-22-2020, 08:11 PM
A floor made from 1/4" plywood and metal so thin you can poke holes in it with a crowbar sounds interesting (or did you mean a quarter of a thicker piece of plywood?).
02-22-2020, 08:12 PM
Coachwork: Ford
Chassis: E350
Engine: V10
It’s fiberglass shell.
I’m having to cut the plywood into small sections and remove it. This will take a few full days if I don’t figure out another method.
I’ve been removing the bolts, set my saw to 3/4” and been cutting. Again, I can’t use a pry bar to lift the sheets.
02-22-2020, 08:13 PM
Coachwork: Ford
Chassis: E350
Engine: V10
3/4” plywood, 1/4 of a sheet of plywood was removed to expose this thin floor.
02-22-2020, 08:14 PM
If the plywood is only ¼" thick over tearable metal -- consider leaving the plywood in place -- it's structural.
02-22-2020, 08:17 PM
I think this is the best and fastest method.
02-22-2020, 09:00 PM
Engine: 6.0L Gasser
It's possible it's a thin galvanized steel. I poked through my non-rusted floor a few times with a crowbar when removing my floor, since the steel was much thinner there than anywhere else. Not sure why they used such thin steel for the floor, though I guess it was more of a moisture barrier, and the 3/4" plywood they put down over it was more of the structural part of the floor. That said, with the plywood out, I could walk over my floor, though it did deflect when I stepped where there were no ribs.
Chris
02-23-2020, 12:22 AM
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
It could be aluminum. My new bus Giridan Micro Bird) is all aluminum skin- inside outside, top and bottom. Much thinner than the steel on my old Thomas.
02-23-2020, 06:42 AM
Coachwork: Ford
Chassis: E350
Engine: V10
The plywood is 3/4” thick not 1/4”
I removed 1/4 of a sheet of plywood To expose this flimsy “metal”
Coachwork: Ford
Chassis: E350
Engine: V10
I was afraid someone would say that haha
02-23-2020, 06:47 AM
Coachwork: Ford
Chassis: E350
Engine: V10
Really? Hmmmm I guess for moisture and weight
02-23-2020, 07:05 AM
Coachwork: Ford
Chassis: E350
Engine: V10
Structural flooring? hmmmm.. Never heard of plywood being structural
02-23-2020, 07:20 AM
Yeah there are some buses- Crown and Gillig- that didn't have any metal for the floor. They were all marine grade ply.
02-23-2020, 07:36 AM
Coachwork: Ford
Chassis: E350
Engine: V10
That makes a bit more sense.
Who knows with this bus.. one small piece at a time.
02-24-2020, 08:56 AM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Probably galvanized steel sheet metal. My shuttle has plywood floor only.
