Old 07-19-2019, 12:06 PM   #21
plfking's Avatar
Rated Cap: 34
Not worth the waste of time.
Puh-leeze......I've seen you break three or four sticks beating the same dead horse.
But more interested in the answer you didn't provide.
2 Nascar Championships and 60 feature wins.
More self-aggrandizement on your part? Your only win that I saw (Google) was a 20-lap race on a 3/8ths mile track (7.5 miles total) against 7 other drivers.
Don
The Busted Flush
Old 07-19-2019, 01:16 PM   #22
I think I found the hitch. Curt 15313. It’s for a Silverado. 1 1/2” more drop than I needed, but I’ll take it. For anyone looking, there’s also 15312 with not quite as much drop, but it wasn’t enough less that I could cut a hole and stub through the bumper. It would have been a notch.
Old 07-30-2019, 01:36 AM   #23
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
Originally Posted by Danjo View Post
I thought the frame rails on the Thomas are wider than the stock Express/Savanna. But now I’m wondering. I’ll do some more research and reply back.
Nope. They're built on the van cutaway chassis. It's distinct from the rest of the vans
dazdconfsd is offline   Reply With Quote
Old 07-30-2019, 01:37 AM   #24
Year: 2006
Coachwork: Collins
Engine: Duramax
Originally Posted by farok View Post
How long of a bus is it? One other point to consider (and one I also have, as I'd like a hitch as well), is on the long short buses (is that right?). They weld extra frame rail to the end of the existing frame rails, to get the full length. Is there any concern welding or bolting a hitch to the extended frame rails on these? I would think not, assuming the original extension was welded properly, but can't hurt to ask the experts here!
Chris
AFAIK That isn't the case on my 5 window, but did appear to be true on my 6 window.
Old 07-30-2019, 01:39 AM   #25
Year: 2006
Coachwork: Collins
Engine: Duramax
Probably too late, but I hope you measured well since the pickups and vans do not share chassis.
Old 08-20-2019, 10:45 AM   #26
Chassis: IH 3800
Well that all escalated quickly. Lol
For the cut-a-way chassis... You'll likely need a "chassis cab" style hitch. Chassis-cabs all have the same frame width to accommodate service bodies, bus bodies, etc..etc.
I just bought one for mine. It is a weld together deal with bolt on or weld on frame plates. Has a 16k rating.
They also have different height drop plates for the frame.
https://www.draw-tite.com/products/t...Li13Jp63vOcso=
I gave $100 for mine on ebay with the frame plates that I wanted.
This is the one with longer side plates for extra drop.
https://www.draw-tite.com/products/t...kWhWRCGvxK9uA=
Old 08-20-2019, 11:52 AM   #27
farok's Avatar
Engine: 6.0L Gasser
Thanks! That's useful to me at least!
My build thread: https://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 08-20-2019, 12:15 PM   #28
The Silverado Hitch fit. I ended up not installing it because I decided that it had too much drop.
I initially looked at those universal hitches, but I couldn’t find a welder willing to do it.
I did find a custom hitch place about 75 miles from me :/
Old 08-21-2019, 08:24 AM   #29
Chassis: IH 3800
Most any fab shop should be able to handle the welding portion. The welds aren't structural so to speak... they just hold the tube in position. Bolt on the frame plates.
I'd talk to your local machine shop or fab shop and ask if they'd do it.
Old 08-21-2019, 09:01 PM   #30
Coachwork: Bluebird, Collins
I modified a hitch to work on my 6 window 2004 Thomas. Didn’t do any welding.
Now on my 1995 Chevy 4 window I’m doing the same thing with no welding. Using angle iron, plates, and big bolts.
Doktari is offline   Reply With Quote
Old 08-21-2019, 11:29 PM   #31
I called around and couldn’t get the word “tow hi...” out of my mouth before they were saying no and no again.
Old 08-21-2019, 11:34 PM   #32
I think I heard mention of an older Ford E450 Hitch with 0” of drop that’s the right width for the Express. I wish manufacturers would make this data available online instead of just “what’s your vehicle “ question.
I want something with a rating so no one can dispute its capacity. I’ll update when I work this out for those that might want to know what I find.
Old 08-22-2019, 11:07 AM   #33
They make drop ball mounts to correct any difference in drop. They can be used right side up, or upside down to raise or lower to level the towed unit.
Old 08-22-2019, 01:36 PM   #34
That’s what I’m doing on my pickup. Turn the drawbar upside down. The problem I see though, is because the tail end distance from bumper to rear axel is pretty long the hitch was likely to drag on steep surface transitions like driveways and steep mountain roads. So now I’m trying to do what you did by stubbing through the bumper.
Old 08-22-2019, 02:26 PM   #35
That’s similar to what I did. I cut a 2.5” notch in my bumper. Them framed it in with angle iron. Reinforced the bumper. Rig is gone so don’t have a picture.
My trailer was only 2000 lbs so I built it to be strong enough for a 3000-4000 trailer. If I was towing a bigger trailer I would have done it a little differently.
tow hitch
