Old 07-15-2019, 01:20 PM   #1
Thomas Shorty Tow Hitch
Hi,
Anyone out there find a tow bar for a Thomas Short Bus?
IDK if there’s common measurements for frame rails. On this Chevy Express the frame rail measures 39 1/2” on center. I need a 4” drop to clear the bumper.
Thanks!
Old 07-15-2019, 08:45 PM   #2
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
I haven't ordered this stuff yet, but what I've found so far for a Chevy chassis is
https://www.amazon.com/Buyers-Produc.../dp/B01CIO5XDO
https://www.etrailer.com/p-118392.html#/
dazdconfsd is offline   Reply With Quote
Old 07-15-2019, 08:54 PM   #3
Not clear if you are looking for a tow bar for the front or a trailer hitch for the back?
Old 07-17-2019, 11:23 AM   #4
Trailer hitch.
So far the only thing I’ve found are the universal hitches that need to be welded.
Old 07-17-2019, 11:41 AM   #5
I thought the frame rails on the Thomas are wider than the stock Express/Savanna. But now I’m wondering. I’ll do some more research and reply back.
Old 07-17-2019, 12:35 PM   #6
farok's Avatar
Engine: 6.0L Gasser
How long of a bus is it? One other point to consider (and one I also have, as I'd like a hitch as well), is on the long short buses (is that right?). They weld extra frame rail to the end of the existing frame rails, to get the full length. Is there any concern welding or bolting a hitch to the extended frame rails on these? I would think not, assuming the original extension was welded properly, but can't hurt to ask the experts here!
Chris
My build thread: https://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 07-17-2019, 01:58 PM   #7
Chris
I wouldn’t worry about that in a vehicle that’s already done a 100K miles. It’s assured that the designers and builders of school buses aren’t going to put a bus body on a substandard frame.
Old 07-17-2019, 02:16 PM   #8
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Would like one on mine as well.
While it will be more costly than a DIY installation, I'll be going to U-Haul for the professional install when the time comes...
Old 07-17-2019, 05:12 PM   #9
Around $20, strong as any commercial product.
Old 07-18-2019, 12:08 AM   #10
I was thinking about that. My bus has a stack of four half inch steel plates between the c channels right about where the hitch would go. I assume it’s ballast? Thanks for sharing that.
Old 07-18-2019, 12:38 AM   #11
I got lucky that there was a frame crossmember 8" behind the bumper. So I took a 1/4" steel plate and welded it to the cross member, then welded the receiver to the plate and all the way around the bumper. It ain't going nowhere. My fold up ramp slids in that hole and sits on a rack behind the plate.
Old 07-18-2019, 07:41 AM   #12
"It ain't going nowhere." Famous last words like let there be light, remember that debacle with the tail lights?
Not what I would call professional welding. Do you think your ins company will approve that? Not enough weld , no place for chain connections, doesn't look like the paint and rust was ground off before welding. Cheap yes, but no excellence built into that for someone with so much experience.
This is why insurance companies don't like home built projects.
I wouldn't be trusting that
Old 07-18-2019, 10:32 AM   #13
Well John, again,you are wrong on all accounts. Everything was ground to bare metal before welding by a professional. My insurance company has no regulations that I know of for mounting a hitch, nor would they have any issue with what I have.
Old 07-18-2019, 11:57 AM   #14
That is not professionally done by any means, you got taken if you paid for that. Sure you didn't weld it?
I have seen much better welding fail...just sayinn
If I were buying that bus and saw that I's run away fast! I thought you were building for ROI, hoping foir 50 or 60k$?
Old 07-18-2019, 05:05 PM   #15
You're delusional.
Old 07-18-2019, 05:36 PM   #16
Well 01, whatever that stands for, you numero uno?
How did that (welder? )ever get a ticket to work professionally?
Is that how low a standard you are building your bus to? With all your experience, how can you allow such "shoddy" workmanship? That bus could be a showplace but it ain't even close, so 60g's might be out of line bud.
Better get that baby xrayed if you know what I mean, lottsa grapes showing.
A chimp can weld better than that with its left foot.
Whatcha plan on towing with that? With or without chains? Will you have trailer brakes? Easy to wire now while you fix the light mishap, no autopsy pics yet?
01marc, the burning man.. lights, skin, whatever
Old 07-18-2019, 06:16 PM   #17
Show me where I said it would be worth $60k or STFU
FYI- 01 was my race car number, 2 Nascar Championships and 60 feature wins.
Old 07-18-2019, 06:38 PM   #18
Well, you know how you like to tell people their bus isn't worth what they are asking, that is you isn't it?
Somebody about a week ago posted their bus and you said yours should be worth 50 to 60k. It's on record here somewhere, no denying that.
Impressive numbers indeed. What was your part in those races. Driver or head welding inspector for Nascar?
So show us some more of your work. How are you going to connect that metallic cable to your incoming ac power source?
What do you think that bus is going to be worth if not 60g's? Maybe break even, it's just one mistake after another mr experience.
So you .... no I'll show a bit more class than that statement of yours.
Buses are fun to build aren't they 01? problems, decisions, oh my!
How do you keep your insanity?
Old 07-18-2019, 06:41 PM   #19
Not worth the waste of time.
Old 07-18-2019, 06:43 PM   #20
Did you google that too for the folks?
It's ok just another bad day at the bus for you.
tow hitch
