Old 08-16-2022, 02:05 AM   #1
Tire pressure on e450
Hey Folks ,
I am looking for the Right Tire pressure for my 2003er e450 Powerstroke skoolie . Maybe someone can help me ? Thanks from Europe ☺️
niprojekt79 is offline   Reply With Quote
Old 08-16-2022, 09:37 AM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Two questions
How much weight is on the front axle?
How much weight is on the rear axle?
What brand, type, and load range is marked on your tires?
Okay I am wrong, five questions.
With that information, I will have enough to answer your question.
William
Old 08-16-2022, 09:37 AM   #3
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Your max tire pressure should be labeled on the side of the tire, as well as the load rating, which may be coded, and you would have to look that up.
I prefer a firmer ride, so I generally run my tires fairly close to max pressure, which also can improve your mileage economy marginally (1-3% or so), but if you want a softer ride, you can let some air out at the cost of mileage/economy.
Otherwise, there should be a chassis manufacturer sticker (from ford, probably on a door, if you have one, otherwise it should be somewhere on that side of the cab that talks about GVWR/GCVW, and should have a line regarding tire expectations.
Albatross is offline   Reply With Quote
