Greetings!
My bus has been going along great after I moved it last month.
My current project has been lifting the wheelchair lift door (Image 1) to meet the lifted ceiling, then filling in the space below the door (Image 2).
This leads to my current problem. My door is ever so slightly off (Image 3). The weather seal no longer meets at the top, and the locking rod is about 0.5 - 1" too low to engage the frame securely. Sorry about not having better images, everything is tarped because we're having an unseasonal 2+ day long rain here in AZ
I'm interested in hearing other's opinions on how to fix/change this.
I think I need to alter my hinges slightly, as that's how it works in a house or on cupboards. Tighten the top hinge or push out the bottom hinge to pull/push the whole thing up slightly
This seems to make more sense than altering the bus version of the door jamb, although possibly both might need to happen.
