Originally Posted by angelicadevries21
Was kicking myself for not bidding so I emailed the seller and it's been reposted! Now that I've been reading around here I'm concerned with it being an electric engine and nonelectric trans, does that cause many headaches? Are they worth tolerating? Also it's a 6cyl and I'd prefer and 8.3L. How big of a difference is there between the 2?
Sent from my SM-G935T using Tapatalk
Whut? electric engine? oh,
electronic. As long as not emissions engine, ur ok.
8.3L is displacement- if you filled all 6 of those cylinders with rootbeer, it'd take four 2-liter bottles and a bit.
edit: do NOT fill your engine with any soft drinks or you will incur soda-lock.
TL;DR non emission bus- good to go. what year?
edit2: 5.9l is also 6 cylinder, just takes less rootbeer. Sooo electronic means it's a 24V engine=more power than non-electronic 12V 5.9L older mechanical version.
trans is a what? 545? how long is this bus/how heavy you going to go? towing not recommended w/ 5.9L & 545 trans.
