Old 01-28-2008, 05:41 PM   #1
Blown IP
So here I am, my bus is blocking my driveway with 2ft of snow around it and a bad injector pump. I have about 13k miles on a rebuilt IP now being sent back to Kansas where the guy rebuilt it. All 13k miles on the pump are veggie and I'm certain that no water has been entering the system. I have a 2 micron Racor water block filter which shows no signs of swelling. It is very cold up here and I have a about 2 ft of unheated veggie fuel line before the shared stock fuel filter. Directly followed by the IP. When the bus shut down it was about 1 1/2 miles after I switched to veg. Good fuel pressure from the lift pump to the IP but nothing after. I even pulled out the fuel cutoff solenoid and got fuel to gush out of that. So every veggiers nightmare just happened to me, hopefully this pump is still under warranty or something. Oh yeah it's a Boesh VE pump off a '89 5.9 cummins.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 01-28-2008, 11:43 PM   #2
phillbus914's Avatar
Re: Blown IP
bummer, was the IP hard to replace?
I'd like to know because I have the same bus/engine combo.
My Old Bus :(
Old 01-29-2008, 10:24 PM   #3
Re: Blown IP
Yeah it's a pain. And you need a special tool to remove the pump. And you need to time the motor just right so when you reinstall the pump it's timed right. The only way to time the motor without taking apart the whole front cover you need to push in this pin which my fat arms can't even reach. I suspect cold veggie as the culprit, it was -10F when it happpened. The oil in the tank was 100F but I think about 2 ft of fuel line got cold and cold veg got to the IP.
89 Blue Bird 5.9 Gen 1 Cummins, Blown Head gasket Apacheglen Cummins Drivetrain 2 01-23-2011 06:06 PM
Need advice - blown head gasket Hornbus International | Navistar Drivetrain 4 10-21-2010 10:48 PM
Blown gaskets? waste-not wagon Skoolie Conversion Projects 0 01-05-2010 03:47 PM
Blown AT 545 dlor1 Everything Else | General Skoolie Discussions 12 04-10-2008 06:21 PM
