Old 07-11-2020, 08:56 AM   #61
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Yeah the 35 gallon tank sucks ..... well if anyone finds a way to have dual 35 gallons or something ... I’m not sure what I’m going to use this tank for I thought about carrying around gas .. barters are welcome also ;)
BusT is offline   Reply With Quote
Old 07-11-2020, 10:24 AM   #62
Originally Posted by BusT View Post
Well it also looks like there is / was a 2in diameter or so hose going into you tank? Was that hose clamped over a nipple or something ?
Kind of like this picture .. I’m trying to find out how the hose is attached ?
This is the point in my build thread where I cut the holes over the tank: https://www.skoolie.net/forums/f11/r...tml#post371452 and you can sort of see where the filler tube goes in.
This is where I started to clean up the tank and you can see things better: https://www.skoolie.net/forums/f11/r...tml#post372528 . I never had any idea what I was looking at exactly, just cleaned stuff up as best I could.
Old 07-18-2020, 10:28 AM   #63
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Do you have a pic of the outside fuel access door ?
Mine has some pretty big gaps and was never meant to be water tight ... I have the cage welded and bolted up under neath the bus and am trying to run fuel filler hose and fuel lines today ...
just thinking what to do about weather proofing the door
Old 07-18-2020, 10:29 AM   #64
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Fuel tank door gaps
Old 07-18-2020, 02:05 PM   #65
I'd love a bigger tank, just don't know where I'd put it on the shorty.
definitely a short bus challenge.. on mine on the left side is where all the air tanks and dryer and such are.. im guessing yours is same way.. behind the wheels between the frame rails is a possibiliy for a second tank, 2nd tank of course adds more plumbing.. with a diesel even more complex as you need to set it up so the fuel return returns fuel back to the same tank you pulled it from
I definitely like the 100gal tank centered between the rails behind the axle.
How many feet of overhang do you have with the shortie?
Also my full size bus being hydraulic brakes -- I hadn't thought about the amt of space required to have redundant air-tanks for air-brakes -- 4 air tanks does take up a lot of space...
David
The Murder Bus
Old 07-18-2020, 03:00 PM   #66
I think this shows why it's waterproof. The hole goes through the outer skin and then that second layer inside (with the grommet around the round hole) is the chair rail. Not much water will get past the outer door because of how it's constructed, and then what does get through would drip off that inner layer. My bus showed no signs of leaking through here.
Just realized I can't get this cover up right now, because the foam board and the chair rail lip together prevent it from coming out. I'm going to have to cut the foam a bit here.
Old 07-24-2020, 09:37 PM   #67
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Ahhh man thank you !!! Just saw this will post when I get mine right!
Old 07-24-2020, 10:30 PM   #68
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
What’s awesome is this is kind of what I had in mine . Going through chair rail then maybe on the I side of the void I’ll box out a little area where if water did get inside it wouldn’t run and just drip through drain holes
Old 04-24-2021, 08:24 PM   #69
Engine: t444E
Rated Cap: 210HP 28,000 GVRW
Originally Posted by eastcoastcb View Post
i'd love a bigger tank, just don't know where i'd put it on the shorty.
on the roof!
godisgood is offline   Reply With Quote
Old 04-24-2021, 10:08 PM   #70
Originally Posted by godisgood View Post
on the roof!
LOL yeah
Doesn't sound fun to me.
100 gallons, fuel tank
