Old 04-05-2022, 10:50 AM   #1
Magiclight's Avatar
Need BlueBird CNG Repair/Service Los Angeles
I have a 1993 Bluebird All American with a John Deere engine that was diesel and converted to CNG. I am having a power issue and believe the CNG lines are clogged or have air and just need service in the Los Angeles area.
Ideally a mobil service as towing will be very expensive. It is parked near LAX.
Would love any referrals or suggestions as hard to find. Thank you
Magiclight is offline   Reply With Quote
Old 06-03-2022, 10:16 AM   #2
Send me a PM of your location .
I'll ask around .
Hawker is offline   Reply With Quote
Old 06-03-2022, 10:24 AM   #3
Magiclight's Avatar
Thanks so much for the reply. The bus is parked in Los Angeles not far from LAX airport. It only drives up to 9 mph due to the problem so hoping for either a Mobil mechanic or somewhat close by for a reasonable tow. Any leads greatly appreciated
Robert
Old 06-03-2022, 10:46 AM   #4
Tejon7's Avatar
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
Please do not give out your exact location or any other information lightly.
Hawker - if you are genuinely trying to help, then I hope I haven't offended you. I would wager that a majority of first-time posters to this website are spammers or bots or otherwise here for nefarious purposes. Given that, asking for someone's location in your first post seems highly suspicious.
Tejon7 is offline   Reply With Quote
Old 06-03-2022, 05:22 PM   #5
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
OP you have computer access so google medium/heavy mobile diesel mechanics for LA area and it should come up.
Old 06-03-2022, 05:49 PM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Hi MagicLight, in your earlier/other thread about this I found a place which you reported doesn't work on buses. You were going to check with Creative Bus Sales 888-633-8380 though...which the first place recommended. Did you have any luck with them? Let us know, as others may need that info someday.
bluebird, cng, los angeles, repair help
