Old 06-16-2008, 08:53 PM   #1
Year: 1985
Engine: Detroit Diesel 8.2L
Need info about Detroit Diesel 8.2L fuel system
Hi again,
has anyone here had experience converting the Detroit Diesel 8.2L engine to burn Veggie oil (WVO)?
Does this model have an injector pump? Or just the fuel pump keeping everything under pressure?
Thanks, Phil
Background:
Hello all you experienced folks. I am fairly inexperienced and need some guidance.
I have a 1985 buebird/Ford with a 8.2L Detroit diesel in it. It will run on veggie oil, I have already collected and filtered over 100 gallons.
Ischgnibargle is offline   Reply With Quote
Old 06-16-2008, 09:25 PM   #2
lapeer20m's Avatar
Re: Help! fuel line question regarding Detroit Diesel 8.2L
i wonder what's inside that line? compressors require full pressure oil lubrication from the engines oil pump. I can't think of any reason why there would be a fuel line running to a compressor. Some compressors also tend to have engine coolant lines also.
i would bet there is either oil or antifreeze inside that unknown hose...theres one way to find out!
Old 06-16-2008, 10:41 PM   #3
Year: 1985
Thanks for the quick response!! It prompted me to stick my tiny camera where my eyes can't see and fire off several shots. That line comes from the oil pan. Good Call, Thanks, and I'm one step closer to T'ing into those lines without unneccecarily breaking anything
Old 06-20-2008, 12:40 PM   #4
Re: Need info about Detroit Diesel 8.2L fuel system
From what I know any detroit is a good motor to run grease. Check out http://www.goldenfuelsystems.com they have a pretty comprehensive list of motor capabilities.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Detroit Diesel Series 50 will fit What? Terrasdad Detroit Diesel Drivetrain 0 11-23-2014 12:35 PM
The sound of a Detroit Diesel 6v-53 frank-id Detroit Diesel Drivetrain 6 11-29-2012 01:00 AM
Detroit Navstart 190 fuel leaking- Badly Duckf00t Detroit Diesel Drivetrain 2 12-14-2009 12:14 PM
My fuel system plans, with diagram. The Eggcrate Alternative Fuels | Electric, Propane, Wood & Biofuels 1 04-21-2009 06:22 PM
detroit diesel 6v71 sound lapeer20m Everything Else | General Skoolie Discussions 2 03-03-2008 09:34 PM
