Re: Overall WVO capacity
I did indeed get them from free from a trashed freightliner. Last road trip i went on was 7500 miles, so I'll have to fill up when I get to the west coast again, but its no problem. I will be putting these things under the bus. At 24 inches tall, they'll be quite low, but still higher than an RV I think. The door frame for the bus and the front axle thing comes down that far, so I just have to worried about very poorly graded areas. My bus should still be able to go over even the largest speed bumps. I will put two steel bars below the tanks and to the sides so that they will scrap first, indicating a bad situation before I hit a tank. I have to create an adapter plate to mount the tank brackets to the bus frame as the holes do not line up, but this shouldn't be a problem.
