Old 12-22-2023, 08:44 PM   #1
Coachwork: BlueBird AA RE
Chassis: Pusher
Engine: 8.3 cummins 24
Rated Cap: 70+
Runnin down the veg.
I thought it was time to share a bit about the bus adventure weíre on. My hope is to help others on this journey and connect with folks who are using SVO in their diesel motors.
So we started out mid September this year from Slocan BC. We have been homesteading up in the mountains there for the past 16 years. We bought a 2000 BlueBird All American 40í pusher that had already been converted. It has the 8.3 Cummins and Allison 3060 tranny. Our family of five were able to move into it after building some overhead storage, food pantry and book shelves. We added a trailer hitch on the rear and another on the front bumper for a bike rack. On the hitch weíre pulling a 8í cargo trailer with dry goods , kids homeschooling stuff , basket weaving supplies and tools. We rented our 4 acre off grid place and hit the road.
Dreamweaver is the name of the bus and she has been converted to also run on veggie oil. Now Iím still learning the system that is in place: 25 gal oil tank, fass fuel pump,heat exchangers, heated oil filter and electric final heater before injection pump. I filter the used oil through heavy duty fabric filter before using and there is also a screw on filter on the transfer pump that moves the oil from. Restaurant tanks to my jugs, s
So far Iíve probably run about 250 gallons of SVO through this motor. There is a toggle switch on the dash to switch from main diesel tank to the veg tank . I make sure to start up on diesel any get motor up to temp before I switch over to veg tank. I make sure to switch back to diesel a few minutes before I shut the motor down. I donít use the veg when driving in the mountains. Or in stop and go traffic.
It works well at highway speeds, I donít usually drive over 55 mph. Finding oil has been tricky. A lot of restaurants are under contract with biofuel companies and donít give it away. That being said, we are still finding it and some places dont care if you come and take it. I like to call and ask over tjhe phone before hand.
We have no intentions of returning to Canada and have made this bus our permanent home, currently we are in Florida around the panhandle and finding enough oil.
Our plan is to head west to winter in AZ . Recently I installed a new fuel pump for the veg oil because old one(fass adjustable) started making loud noise and check engine light came on when I switched to veg tank. When I switch back to diesel light goes off. After installing similar new pump it worked great for couple weeks and now check engine light comes on again when running veg for a few minutes and goes off again when I switch back to dieselÖ
I think I will try and increase pump pressure and check filters. I hope we can keep this system running any help would be great right now diesel here is around 3.70 a gallon.
Hope this is not too much to share , blessings ,
mtnfreak is offline   Reply With Quote
Old 12-27-2023, 08:43 AM   #2
Tin Roadtube Vagrant's Avatar
Chassis: Chevy Kodiak
Engine: 3126B CAT
Rated Cap: 27K
Hope it works out for you. I could share some horror stories of what I've seen those "oil eaters" do to the fuel system of my customer's Semi and how much it cost them to have us fix it. A'course I'm not going to be the wet blanket, good luck.
Tin Roadtube Vagrant is offline   Reply With Quote
Old 12-27-2023, 02:38 PM   #3
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
check out johnny mullets build thread.
he did a waste oil set up but i dont remember what engine he had.
Old 12-27-2023, 09:36 PM   #4
Chassis: Pusher
Rated Cap: 70+
Road magic
Ok Iíll check it out, went to go pump some veg oil today
Behind a seafood place in Mexico Beach FL. And the owner drove by and chatted me up about the bus and our journey.
He said it was the last time we could pump there because heís under contract but let us fill our boots AND he gave us a 200 dollar visa gift card and wished us luck on the. Road.
Man, thatís what I call road magic!
Old 12-30-2023, 09:04 PM   #5
Chassis: Pusher
Rated Cap: 70+
Update on the check engine light when running the. Veg oil. Ran the code on scan tool and came back
As low fuel pressure at injection pump. So changed out both fuel filters and no more codes so far.
Phew. Gonna increase change interval on fuel filters from now on and still run 20% diesel in the veg tank
I know the CAPS system might not like it and have heard the stories of what is gonna happen but man I want it to work.
I will keep you all posted thank you for all the help. Happy new year
svo, veggie converted bus
