Old 05-14-2019, 09:32 AM   #1
Chassis: Saf T Liner MVP EF
Engine: CAT 3126B + Alison AT545
Suggestions - 50lb propane tank
Hi All,
The previous owner of my bus placed the tank on the inside. rear-right corner of the bus.
Was wondering if this was safe if paired with a monoxide detector.
Any suggestions? Is this safe?
Aegis2x is offline   Reply With Quote
Old 05-14-2019, 09:33 AM   #2
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Aegis2x View Post
Hi All,
neither safe nor legal
Old 05-14-2019, 09:54 AM   #3
OK, to the drawing board!
Any other input or recommendations appreciated on mounting hardware and/or tanks. I have not measured diameter yet as its planted in another town at the moment.
Plans are to run a stove, heater(rarely), maybe a fridge, and lastly a propane shower meant for outdoor use that I plan on setting up so the shower vents out the window.
Old 05-14-2019, 10:30 AM   #4
Propane tanks need to be outside of the living area and in a vented enclosure.
Inside the bus you need a propane detector and a CO monitor.
Old 05-14-2019, 11:21 AM   #5
HazMatt's Avatar
Chassis: IH 3800, 8 window
Too late to the party...
What he said!
HazMatt is offline   Reply With Quote
Old 05-14-2019, 01:10 PM   #6
Yes better underneath outside.
But you can just fully enclose the bottle
so its space is airtight wrt the living space, and vented out the bottom to the outside.
Old 05-14-2019, 01:39 PM   #7
With that many gas appliances I would put a large tank in underneath. I have a 29.3 gallon tank for sale here, brand new. I mounted it under the right rear corner of the bus. I don't know where you are or what bus you have to know if I can help. Go to the UserCP and fill out your profile so we can better assist you.
Old 05-14-2019, 01:42 PM   #8
Trying, keep getting this:
Change has not been done because user session is not valid.
Old 05-14-2019, 02:06 PM   #9
All your propane answers are here. NFPA 1192. Read free online.
https://www.nfpa.org/codes-and-stand...tail?code=1192
Old 05-14-2019, 07:13 PM   #10
Bus is gonna be sitting in Beckley, WVA in about 3 weeks or so.
