Old 11-17-2008, 07:35 PM   #1
SoulFire's Avatar
Year: 1979
Chassis: Super Coach
Engine: Detroit 6L-71 Turbo
Viton hose best way to go?
I'm wondering what kind of hose people are using for their veggie. I've heard a lot about Viton...is that the best way to go? If so, where might I find a cheap deal? I'll need sufficient hose to run from the fuel tank in the back to the engine (it's a mid-engine) then also hose for the fuel return lines. Possibly around 30 ft of hose.
Thanks!
SoulFire is offline   Reply With Quote
Old 11-18-2008, 08:00 AM   #2
Re: Viton hose best way to go?
run hard(steel)lines to/from the tank & engine and use flexable hose at the ends to make the connections and allow for vibration and mis alignment.
DOT regulations allow for only 18" of continuous hose then it must be hard lines.
Old 11-19-2008, 10:33 AM   #3
copper lines = bad, they will work harden from vibration over time and then stress crack and break, DOT mandates either steel tubing (brake line) or an appropriate plastic that the fuel will not compromise, also use DOT approved fittings. the proper parts are available from your local truck parts supplier.
Old 11-29-2008, 08:26 PM   #4
Yeah don't use copper for veggie it reacts with it and turns a green tarnish color. On www.mcmastercarr.com you can get flexible aluminum tubing for a pretty good price. Otherwise Viton will work well.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Hooking up air hose / air tool to the air break compressors? GoneCamping Conversion General Discussions 28 09-11-2017 07:14 AM
Galvanized Pipe for Heater Hose? porkchopsandwiches Conversion General Discussions 10 04-12-2014 06:55 PM
Flexible exhaust hose for generator Ob1 Mechanical and Drivetrains 7 11-17-2009 12:03 AM
hooking air compressor hose to air tank? TikiBus Everything Else | General Skoolie Discussions 3 11-02-2008 09:10 PM
Hose Type size and fittings copper hih lapeer20m Alternative Fuels | Electric, Propane, Wood & Biofuels 3 04-02-2008 01:32 PM
