Old 06-15-2009, 07:45 AM   #1
Year: 2012
Coachwork: Need bus-as-home over RV
Chassis: still looking
waste MOTOR oil as fuel??
Not sure where else to put this but i'm sure some of you must have seen some of the claims of people mixing used motor oil in with diesel (after filtering) and some people even using 50/50 blends and one guy claiming he ran it straight... does anyone know anything about this?
I would think it would be hard on injectors (with any kind of micro particles at all despite good filtration, i'm not sure what size particles would be considered harmful or how much filtering would be needed)
nearhomeless is offline   Reply With Quote
Old 06-29-2009, 04:48 PM   #2
Steve's Avatar
Re: waste MOTOR oil as fuel??
I know and have heard of a lot of people doing this. They say you can use up to a 50/50 mix. I would filter the oil well first before putting it in my tank. I was going to experiment around with this first with my tractor and then try it with my bus.
Old 06-29-2009, 09:34 PM   #3
lapeer20m's Avatar
were you going to try and use it in a gas motor steve?
Old 06-30-2009, 03:20 PM   #4
Steve's Avatar
No I don't think that would work very well! My tractor and my new bus are both Diesel.
Old 06-30-2009, 06:22 PM   #5
lapeer20m's Avatar
i read this post BEFORE i saw you had a new bus.
i think a centrifuge would be an awesome method for filtering used motor oil. Also, i bet that DD will burn just about anything you put in it....and it doesn't have a single injector pump, rather each injector is it's own pump which means that if things do go bad, you can at least still get home even if one or more cylinders stop producing power.
Old 07-01-2009, 11:06 AM   #6
Steve's Avatar
Originally Posted by vanguy67
Considering the amount of oil the DD is prone to sling (They put "slobber tubes" on them AT THE FACTORY ), you could probably just filter the oil through an old sock and the DD would burn it...
I hooked both the tubes up to a container (an old coolant jug) to collect it already. Although I have a vent hole on the jug it should keep clean enough to filter and burn.
You're not gonna be too good to associate with us lowly skoolies now...are ya??
I'm not planning on getting rid of the skoolie, I am working on both of them side-by-side right now.
How About these for waste tanks? Stu & Filo. T Conversion General Discussions 8 01-22-2014 11:51 AM
Have 2 new waste tanks I don't need Anthony Everything Else | General Skoolie Discussions 0 05-17-2013 11:03 PM
Cheapest straight veg oil? (not 'waste') nearhomeless Alternative Fuels | Electric, Propane, Wood & Biofuels 0 05-18-2009 09:09 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 10:31 AM
waste oil burner lapeer20m Everything Else | General Skoolie Discussions 12 10-16-2005 11:27 AM
