Old 05-20-2020, 01:26 PM   #1
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Airplane bus
Guess I'll just start where I'm at and fill in as we go. Two years deep in this bus and probably a year from being (mostly) complete if there is such a thing.
Currently building the access channel covers in the bathroom. They carry ductwork and water lines.
Simple cheap pine sanded,cleared
Form&function is offline   Reply With Quote
Old 05-20-2020, 01:27 PM   #2
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Not exactly sure how to rotate pictures?
Old 05-20-2020, 02:55 PM   #3
Ah, I was going to ask how that ceiling toilet worked.
Convert your pics to PNG format (and make sure they're rotated the way you want them to be) before posting them.
Old 05-20-2020, 03:42 PM   #4
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Had to build a seat base because I wasn't capable of cutting a huge round hole in porcelain.
Old 05-20-2020, 03:44 PM   #5
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
[QUOTE=musigenesis;387792]Ah, I was going to ask how that ceiling toilet worked.
Got it,thanks
Old 05-22-2020, 12:27 AM   #6
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Refinished this 100 year old door. The led staining looks pretty cool. Way too much work though and set me back two weeks.
Old 05-22-2020, 12:30 AM   #7
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Metal door frames with rubber seals so they dont rattle.
Old 05-22-2020, 09:28 AM   #8
What is led staining? Door looks good, as does the whole bathroom.
Old 05-22-2020, 12:50 PM   #9
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Sorry, lead paint staining the wood in spots.
Old 05-22-2020, 12:55 PM   #10
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Originally I was going to build my shower walls out of red cedar covered in epoxy. After a brisk learning curve with the epoxy I realized it wasn't in my budget or time frame so I scrapped that idea.
Not wanting to waste the test panel I cut it up into the coffee table/side table.Click image for larger version
Old 05-22-2020, 03:11 PM   #11
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
Some folding hinges I stole from a rotted fifthwheel.
Old 05-22-2020, 04:53 PM   #12
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
I sure like this epoxy stuff.
Old 05-22-2020, 05:01 PM   #13
Way to repurpose failure!
Old 05-25-2020, 12:28 PM   #14
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
I put buttons on the seats. You can buy these from Wally world. Pretty easy to do and comes with the little punch.
Just slid the fabric over a piece of would so it could be punched.
Old 05-25-2020, 12:30 PM   #15
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
It's a little industrial but doesn't bother me.
Old 05-25-2020, 12:37 PM   #16
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
I really like these grommets and they're cheap.
Easily purchased at any harbor freight. Works well for privacy.
These hooks are welded on but they make all kinds of hooks.
Has a reversible insulating pad,white on one side and dark on the other.
Old 05-26-2020, 04:18 AM   #17
In a way, I like that you started at this point in your build. There are MANY build threads showing rough-in, insulation, etc. Not many showing the finishing touches.
Old 05-27-2020, 04:21 PM   #18
Elliot Naess's Avatar
Engine: 5,9 Cummins
All right, I'll bite. What is the "airplane" angle?
Old 05-27-2020, 09:51 PM   #19
vintageracer's Avatar
Not worth a schidt.
Sorry I couldn't resist!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
vintageracer is offline   Reply With Quote
Old 05-27-2020, 10:20 PM   #20
Year: 1978
Coachwork: Gillig
Chassis: Neoplan
Engine: 8.3, 653
Rated Cap: 36k
The guy that started the bus was a aircraft mechanic and its built like a military cargo plane.
