Old 02-22-2020, 11:07 AM   #1
Chassis: Saf-T-Liner MVP ER
Engine: Cumming ISC 6-cyl Diesel 8.3L
Front Wheel Locked
Cranked the bus this morning. Let air pressure get up. Put into gear. Front right wheel is locked. Any ideas?
BDFulbright is offline   Reply With Quote
Old 02-22-2020, 11:21 AM   #2
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Check the adjustment on that brake (and the others). Could be that the S cam flipped over, but I don't recall if that causes them to lock up or not work. Could also be a failed air can. The air brakes are designed to stay locked on when they fail.
Dave
ermracing is offline   Reply With Quote
Old 02-22-2020, 05:25 PM   #3
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
yes the cam could cause it but the front brakes do not lock up in park like the rear. shoes sometimes get debris in them or wheel bearings are bad
mmoore6856 is offline   Reply With Quote
Old 02-22-2020, 05:28 PM   #4
My first question is air or hydraulic brakes. Hydraulic brakes can lock up, typically from an internally collapsed rubber hose, or a seized caliper.
When air brakes "Cam-Over" it does not lock. In fact, there's no braking action at all! (This is why it's a really Bad Thing.) There are *NEVER* parking brakes on a steering axle, the logic being you still need to be able to steer and control the vehicle even if a "can" fails while you're driving (it can happen).
Old 02-22-2020, 08:11 PM   #5
mmoore6856's Avatar
Chassis: chevy
i beat a slack adjuster a few times as the s cam was on the tip and did lock the brakes up so it has happened
