04-25-2017, 11:41 AM
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
Marky's Conversion!
Wife and I got a coach bus for about the same price as the 2002 RE IC we were looking at about 1 1/2 months ago. We figured if we're going to do this, we're going to go big. And big it is....
Manufacturer: NEW FLYER
Model: D45HF
Length: 45'
Width: 102"
Height: 135"
Curb Weight: 36,500
Floor Height: 55"
Radiator: Brocksopp
Hydraulic Pump: Sauer Danfoss
Passenger seats: 57 (14 rows, 2 seats each side of aisle, 14th row has extra seat in middle)
Engine: Detroit Diesel Corporation Series 60
HP: 330
Transmission: ZF-602C 5HP ECOMAT2
Retarder: Yes
Heat and A/C: Thermoking LRT-2
Axle Ratio: 4.88: 1, Meritor
Body: Fiberglass & Aluminum
Tires: B315/80RX22.5
Antilock Brakes: Meritor
Programmable Logic Controller: Allen Bradley SLC 500
Charging System: Nieoff C801
Mileage:435,375 (approx)
I'm trying to get pics up, but my kids have commandeered my laptop and I'm trying to post from a tablet - not the easiest thing to do....
The innards work just fine (had it delivered from 600mi away!), but the body needs work. And, oyah, the dash needs a LOT of help.
04-25-2017, 11:56 AM
Chassis: E-450
Engine: 7.3 Turbo
Pics don't seem to be loading...
But congrats on getting a bus!
04-25-2017, 11:58 AM
Rated Cap: 51,600
04-25-2017, 12:42 PM
Nice buy. That is a beast. The seats just go on and on and on.
At least with the width of the coach you shouldn't have the same insurance troubles as actual school buses.
Nice choice.
Robin
Nobody's Business
04-25-2017, 02:07 PM
Rated Cap: 51,600
Nice choice.
Thank you for your kind words! It is a beast. I've been caught a few times just standing in front of it looking at it wondering "crap, what did we just do?"
I'm gonna need alot of help....
04-25-2017, 02:11 PM
plus with a coach you end up with a lot of "basement" area to put stuff.. more than a skoolie... in my opinion helps out for mounting various components.. but I havent built one so I dont know.
04-25-2017, 02:30 PM
We're fixing up buses. It's obvious we all need help. Luckily we all have the same bus psycosis.
Robin
Nobody's Business
04-25-2017, 02:39 PM
Rated Cap: 51,600
Some of us are a little farther "down the road" on learning about their psychosis than others....
Me, eh, not so far....
04-25-2017, 02:49 PM
That's true. It's a sickness that is only controlled by our budgets.
Robin
Nobody's Business
05-06-2017, 01:36 PM
Rated Cap: 51,600
What are these things?
Does anyone know what this is? Its mounted in the luggage rack just behind the driver's area.
I think this is a J1939 connection. Can anyone verify?
05-06-2017, 01:56 PM
gray 6 pin is normally J-1708 which will run on the J-1587 protocol,
if its pin then its a 1939..
the TMS boxes were black-boxes, data recorders for the busses that read the data offd of the computer link... they opften were used for maintenance schedules and sometimes crash investigations.. i didnt see enough pics to know what all is there.. cool stuff though.
05-06-2017, 02:03 PM
I just looked that box up.. its maker was sold off in 2008.. it appeared to be a SATNAV based tracking / dispatch system.. makes sense for a new flyer which was likely a city-route bus at some point im guessing?
Rated Cap: 51,600
The city of Houston ripped a bit of it out when they sold the bus, but the ZONAR stuff mounted around lends credence to your explanation. I tried to find information about some of this but hit a brick wall. What other pictures do you need?
I'm trying to identify what I should keep and what can go as I start ripping. I'm a techie, but even so the number of wires running to and fro boggles my mind....
05-06-2017, 02:14 PM
ZONAR is worthless get rid of it.. its mainly used to make sure the driver does the daily walk through of the bus.. theres usually buttons around the tires, engine bay, sometimes even underneath near the air tank drains, etc..
the orbital stuff is probably worthless now.. 9 years since the company was sold not likely to find any updates or parts for it... houston probably kept the stuff they still use for spare parts..
the round connectors are your diagnostic ports... youd have to trrace the wires to see if those are the main ones directly from the ECM (and possibly TCM(tranny)).. or if they were auxilalries for that TMS unit.. ..
its hards for me to go afyer that stuff remotely through pics.. im used to crawling around and ohming, and imagining how it was designed... often you can tell afterm,arket wiring from factory.. I know on both my busses i figured out what was factory and what was added by the differences in how wiring was routed, the tubing, and the wiring type / quality..
I tend to remove only what I need.. then drive the bus test all functions.. then yank a little more, do it over again till i end up seeing a WARN ENGINE light, or something just goes defunct and doesnt work anymore
Rated Cap: 51,600
Wow, you're good. I hit a brick wall and couldn't go any further.
As for a city-route bus, yes, for the city of Houston. Unfortunately I don't know what the route was. The bus itself is more than capable of highway speeds (I think the rear-end ratio is 4.8 .
05-06-2017, 02:23 PM
Rated Cap: 51,600
Will do. I figured that was what that was from the ZONAR website.
Yea, I figured I'd go ahead and put it up on eBay and see who bites, but I'd like to put a whole "package" up and get rid of it all.
Ok. I'm hoping its the main ports. The previous owner said they were, but he also told me they were J1939....
-Christopher[/QUOTE]
I'll keep that in mind. I may end up following the same process since I'm going to be learning as I go. Thank you for the wisdom....
05-06-2017, 06:40 PM
for your ports.. if they have 9 pins in them then they are 1939, if they have 6 pins they are 1708's , most of the 1939's ive seen are green but that doesnt mean anything.. the number of pins calls it..
05-07-2017, 04:20 PM
Rated Cap: 51,600
I looked at my schematics and found the J1939 bus on it. It runs between the engine, tranny, and ABS brake controllers. According to the schematics it doesn't go anywhere else.
However, the ABS brake controller seems to have several J1708 ports. Guess I will get one of those USB-to-Jwhatever adapters and see what I can see.
It seems strange to me that New Flyer wouldn't have brought out either the J1939 or some other port for diagnostics - even an OBD/ODB-II. Any idea about that? Is that what the J1708 port(s) were for?
05-07-2017, 05:15 PM
that bus may run on J1708 and not use J1939 for the diagnostics.. there may be 1939 between basic controllers.. and then only 1708 for diagnostics.. OBD-II is consumer passenger automobiles only.. you wont find it on anything medium / Heavy duty..
to talk to it you'll not only need an interface but software for it.. I have a SilverLeaf VMSpc that talks 1708 and is a view only type device... i use it for my daily driving on a Tablet moiunted to the dash...
for read / write on my bus I have the Nexiq USBLink2 and then navistar gives away the basic software...
I dont klnow what software you would use for your bus? the VMSpc mioght work as a display only.. would have to hook it up and see what comes across...
05-07-2017, 05:25 PM
Rated Cap: 51,600
Yea, I found the sliverleaf from offgr1d's coach build thread and investigated. I like what I was seeing. However, I have programming skills and was wondering how far I could take that, so I'll look into the Nexiq.
Thanks!
