Old 08-27-2023, 12:46 PM   #1
2000 International/ DT-466 Not Starting (see video)
Help!
Just tried to start up my bus and it wonít start. I started it up about a month ago and it had similar trouble starting but eventually kicked in and ran for a few hours. Now it wonít start at all. See video here.
Any ideas?
Beeb2 is offline   Reply With Quote
Old 08-27-2023, 01:03 PM   #2
ewo1's Avatar
Originally Posted by Beeb2 View Post
Help!
Any ideas?
Batteries are DEAD !
Recharge 24 hours or replace with new.
Old 08-27-2023, 01:07 PM   #3
The batteries were replaced just a couple months ago and are left completely disconnected when the bus is not in use. The symptoms in the video I linked to also donít seem to match dead batteries. Iíve had the batteries die before, and thatís not what it sounds like.
Old 08-27-2023, 01:26 PM   #4
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
check battery voltage and clean the cables.
see if it will start by jumping the start solenoid.
Old 08-27-2023, 02:52 PM   #5
ewo1's Avatar
Go to this thread and read post #3 for some good detailed info on disconnected batteries..
https://www.skoolie.net/forums/f49/2...tml#post497232
Old 08-27-2023, 03:27 PM   #6
Thank you all! I checked battery voltage with my multimeter and it looked fine, but the connections were in fact very dirty. I cleaned them all up real good and tried again and the bus started up easy on the first try, just as beautiful as ever. Thank you all! This place never fails.
Old 08-27-2023, 03:35 PM   #7
ewo1's Avatar
Great news...Now go get ready for that nice little rainstorm heading your way!
Old 08-27-2023, 05:47 PM   #8
Coachwork: Busless for now
Glad it was so easy!
Now listen to this: If you don't start the bus regularly, you MUST hook up a charger/maintainer! If you have shore power, plug it in. If not get a small solar charger/maintainer.
Kentucky Dreaming is offline   Reply With Quote
dt466, help me, international, mechanic, no start
