Old 10-19-2017, 11:00 AM   #1
Chassis: GMC Bluebird
ABS light?
So I just got a bus and on the way home the ABS light would intermittently flash on and off. It was pretty random. Any ideas? Also the speedometer and tachometer do not work, any "easy" fix for this that you know of? Thanks. PS. painting this w/e, any tips?
joshjohnson17 is offline   Reply With Quote
Old 10-27-2018, 10:49 PM   #2
Bon Voyage's Avatar
Rated Cap: 81
what ended up happening with your abs light? I've got mine on and am trying to diagnose the problem
Bon Voyage is offline   Reply With Quote
Old 10-28-2018, 12:11 PM   #3
About the only thing you can safely do with ABS systems is to check for obviously broken wires or heavily crudded up sensors. That failing, take the bus to a qualified service center and get the system checked using their computer diagnostics. The life you save might be yours--or one of ours.
Old 10-28-2018, 01:18 PM   #4
Check out this other thread.
http://www.skoolie.net/forums/f49/ab...tml#post296307
84chevyguyid is offline   Reply With Quote
new bus, new bus owners
