10-22-2021, 12:44 PM
#21
Chassis: International 1753
Engine: 6.9 International
It's a ring issue typically. Excessive idling will wipe them out in a hurry. High idle is better, but still isn't "good". Moral of the story is don't start or run it if you're no intending on driving it.
10-22-2021, 12:49 PM
#22
high idle was always a given.. I knew of ring issues on cool engines at low idle.. i always ran them at 1200-1400 till the Tstat opened then shut down.. on a diesel bus this was 30 minutes or more since the heater loops have to warm up too...
I do agree driving is best, for one it frees up the transmission, brakes, suspsension, gets the grease moving in U-joints, etc..
I just never thought of warm-up idling hurting the motor is all.. seemed better than letting an engine sit for a year untouched
10-22-2021, 07:37 PM
#23
Chassis: chevy
Engine: 3116 catapillar
yea thats right and i never had any issue getting the water and oil warmed up. even at 5 below as i keep a good thermostat in it. i do have a winterfront too but you do need to circulate the oil so they dont seize. i rebuilt a diesel years ago it ran good when he parked it and it sat for about 16 months. when he started it it spun a bearing and squealed loudly. luckily he shut it down but i had to replace the rod bearing and a main that spun too. turned the crank and told him to run it for at least a half hour every month. he never had any issues again.
10-22-2021, 07:56 PM
#24
The winter front.. my dev bus has an automatic winter front and it really helps even on the road..
10-22-2021, 08:29 PM
#25
Oh wow guys! So many answers.
Thank you to all of you!
I am living in winter climate where temp drops as low as -30C(-22F) or more and I have built an understanding that its not good for an engine to sit over a year in that condition. And I also do it at least couple times a month, each at least 30 min. First couple minutes with high idle.
But thank you very much for you recommendations. I have lot to learn. I unfortunately cannot drive the bus, because it is currently my living space which is still under construction to become a proper RV.
Complicated story.
I know it sucks.
I am looking ways to maintain and fix the air issue and thank you for your help. I will take more pictures and post here if that will help.
10-23-2021, 09:36 AM
#26
Chassis: chevy
i always liked those had a mad max look
10-23-2021, 10:00 AM
#27
mine is behind the grill you cant see it.. it is a shutter that open and closes with temperature when its enabled.. I have a switch on the dash so I can disable it, otherwise it is auto.. even in minus-degree weather the bus warms up nicely with it enabled..
10-24-2021, 08:47 PM
#28
Hey guys!
I made same pictures and a video (uploaded with a link) to show more detailed what, where and who.
Heres a link to a video:
https://www.dropbox.com/s/7brt6mm8f4...ts-ts.mp4?dl=0
So you can hear the sound of air coming out in pulses.
So as I understand the air needs to be emptied from the bigger tank, that has a little knob under its belly?
10-25-2021, 09:56 AM
#29
Pulsing is because the compressor is a piston pump, not a gear pump, so it pumps in pulses.
The reason it's coming from the dryer and not building pressure is caused by your purge valve being stuck open. Refer to my post here for your options on fixing.
This video shows how to rebuild an ad9 dryer off the vehicle.
10-25-2021, 10:22 AM
#30
Engine: Navistar 7.6L
Both tanks have a drain valve.
10-26-2021, 09:44 PM
#31
Thank you very much guys!
Thank you, Booyah!!! You have been very helpful. I will do what is necessary.
And will let you know how it went.
10-27-2021, 03:24 PM
#32
Year: 2005
Chassis: Thomas HDX
Engine: Cat 7.2
That literally just happened to me last week… Replace the air brake governor and then reset the purge valve by pushing up on the bottom of it with a small block of wood while the engine is running you’ll start building pressure instantly and all should be well… At least it was in my case. Best of luck!
10-27-2021, 10:44 PM
#33
Do Not
Drive it. When air brakes loose air the huge spring in the pots presses the brakes and turns them ON. Contact a truck repair shop
And have them fix it! You risk killing yourself and others. Don’t mess around with bad air brakes.
10-28-2021, 08:47 AM
#34
He's got juice brakes. The air system is for the suspension and other misc. accessories.
10-28-2021, 02:48 PM
#35
Do any of the buses have air assist hydraulic brakes?
10-28-2021, 06:00 PM
#36
air over hydraulic.. ive not seen it in a bus but have run across it in a box truck.
doesnt mean it may not exist though..
10-29-2021, 07:29 AM
#37
a lot of military stuff ran that. Old tech from the 50's or so.
11-07-2021, 09:56 AM
#38
To replace the purge valve. Is there any precautions I should take, before I remove the old one?
Empty the tanks or...?
Was the Air Governor easy to replace for you?
Is there any precautions before I dismantle it?
11-07-2021, 11:33 AM
#39
Year: 2005
Chassis: Thomas HDX
Engine: Cat 7.2
It was super simple to replace, it took 20-30 minutes. I dumped the air then I cleaned the old Governor and the area around it so I didn’t contaminate the airlines when I removed them. Keep good track of where the airlines bolt to the Governor, mark them if necessary so you don’t get them mixed up. I had to reuse the fittings between the line and the Governor since the new Governor didn’t come with them. Be sure to use Teflon tape on the pipe thread side only on the fittings and on the pipe plugs where no fittings are used. Hope this helps.
11-08-2021, 08:55 AM
#40
Any time you work on any air component on the bus, dumping the air tanks is step 2, with step 1 being chock the wheels.
Once the tanks are drained, you're good to go.
