12-18-2021, 01:12 PM
Coachwork: Crown Coach
Engine: DD6V92T
Rated Cap: 88
Air spring help needed!
Is it possible to swap out an air spring for one of a different part number but similar makeup?
I have a total of 4 Goodyear air springs on the rear of my bus and one of them has a leak. Unfortunately there are no replacements that i can find for it anywhere. I called every shop from LA to NYC and checked all the cross references too i.e. Firestone/Ride-rite, Meritor, Continental, and everything in between. No one has any in stock because there seems to be some sort of mass back order on these things, with lead times all over the board... most around 12 weeks. I might just have to wait it out, but I thought I would see if anyone had any other ideas.
Thanks in advance!
12-18-2021, 04:28 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
PM crown guy
reach out to the other crown owners on here like
rossvtaylor
tejon and several others
or just crown crown crown and you will get a response
12-18-2021, 05:25 PM
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
Originally Posted by Jolly Roger bus 223
PM crown guy
rossvtaylor
Thanks for the vote of confidence, but I'm clueless on this subject. The only air bag on my bus is in the driver's seat. I'd add Iceni John to the above list of forum members to reach out to - he has a Super II maybe with air suspension?
12-18-2021, 09:51 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
my dive into air springs
I have a friend with a 1994 bluebird with rear air springs..... It appears the original part numbers are no longer made.
However, there also seems to be six or seven choices that will get the job done.
The differences in the six or seven I consider to be interchangeable all have to do with variations of the internal bump stops. The bag, the base plate, the the top plates, bolt hole locations, and sizes are part of what can be different.
In my case the only dimensions that vary are the internal bumpstops. The prices go from $150 to $450 per bag. Some part numbers are used much more often.
I spent about four hours a day for a week learning about firestone, good year, and other brands and how they interchange, how the part number systems work and load ratings.
william
12-19-2021, 12:02 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I've got Crowns with air bags (air springs) but I can't tell you the right part numbers right now. But if you contact Michigan Truck Spring ( https://www.truckspring.com/ ) with your current part number they can get you a compatible replacement option. I've bought from them before and found them to be very helpful. There are lots of suitable options which work just fine.
EDIT to add: There does indeed seem to be a long backorder on air springs right now.
12-19-2021, 12:14 AM
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
My new Crown has air ride tandem axles. If it warms up a taste I can go and look at it and take pictures. My "old Crown" has leaf springs. Crown didn't make the suspension but bought from existing vendors. I would suggest looking to a truck wrecking yard for the parts, but I think changing to air ride is a really big project.
12-19-2021, 01:31 AM
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Unless you have to drive the bus I would wait for the same airbag as what is installed or a cross reference bag from another manufacture that has the same specifications. Too large a difference between a replacement and the original could cause problems with installation or ride height.
Ted
12-19-2021, 07:59 AM
Engine: DD6V92T
Rated Cap: 88
Thanks! I talked to IceniJohn a couple of weeks ago and unfortunately he has leaf springs all around.
12-19-2021, 08:05 AM
Engine: DD6V92T
Rated Cap: 88
william
Thanks! This is exactly what I was thinking about. I'm going to check all the original specs and dimensions on the Goodyear part and see if there are any air springs out there with similar setups. I spent more time just trying to track down the actual air spring than anything else lol.
12-19-2021, 08:09 AM
Engine: DD6V92T
Rated Cap: 88
I talked with Michigan Truck Springs a few different times and they weren't able to help. Super nice though! I think our air spring is just an oddball and there aren't many options available out there. Just one of the perks of owning a Crown
12-19-2021, 08:16 AM
Engine: DD6V92T
Rated Cap: 88
Ted
Thanks Ted. I'm in a little bit of a pickle right now. The bus is at Bus Grease Mountain gettin a once over from Scott(BGM). We dropped it off on our way south for the winter. The plan was to continue our conversion down here but the bus has been stuck at the mechanics waiting for the air spring. I'd like just wait for 4 new air springs from Goodyear but the clock is ticking... might just have to wait. We are enjoying the warm winter down here though. Happy Holidays!
12-22-2021, 04:04 PM
Chassis: F33695
somebody has one, you just haven't turned over the right rock yet.
12-22-2021, 04:49 PM
Try Fleetpride in Klamath Falls Or 541 884 5103. They have a LOT of airbags on the shelf.
12-22-2021, 06:11 PM
What are the original part numbers?
I’d be happy to make some calls down here in So. Florida to see what’s available.
12-22-2021, 06:54 PM
Coachwork: -
Chassis: -
Engine: -
Any chance of repairing your bag??
( https://liveworkdream.com/2020/01/15/fix-burst-airbags/ )
...maybe some truck repair station can - at least temporary - patch your air-bag, so you can continue until you can get spare-parts?
thjakits
12-23-2021, 02:20 AM
Get the Goodyear catalog. It has specs for all the springs they make.
Try salvage yards that deal in heavy trucks. I got one from a salvage yard.
I got new ones from Stengler Brothers. They somewhere East. $312 for both.
12-25-2021, 01:45 PM
Engine: DD6V92T
Rated Cap: 88
The Goodyear number is 1r11-066 Any help is appreciated. Thanks!
12-25-2021, 01:51 PM
Engine: DD6V92T
Rated Cap: 88
I actually have a standing order with the Stengel Bros. Their lead time was the least overall. Hoping 4-6 more weeks. I’d like to find them sooner though, so I’ve called salvage places too. Tricky part to find.
12-26-2021, 05:57 AM
Chassis: chevy
Engine: 3116 catapillar
before installing and yearly it helps to spray them with a rubber preservative
12-26-2021, 11:30 AM
Engine: DD6V92T
Rated Cap: 88
Great info, thanks! Are there any other good applications for the spray on/under the bus?
