Old 01-30-2021, 12:19 AM   #1
Air up your tire?
What do you people use to air up your tires? Mine are 115psi on the outside or tires marked. Thats the max of my air compressor, so I am skeptical that I can get that high.....
Skoolagain is offline   Reply With Quote
Old 01-30-2021, 12:26 AM   #2
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Engine: International T444
Rated Cap: 16?
Any harbor freight pancake compressor will make 150psi.
ISAF2009 is offline   Reply With Quote
Old 01-30-2021, 12:27 AM   #3
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Rated Cap: 16?
Make sure to inflate to the specs on the vehicle not the tire.
Old 01-30-2021, 12:36 AM   #4
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Rated Cap: 16?
Just walked out to the garage to chase the possum away, my inflator is a viair 440p. It will inflate the rear tire on the massey ferguson without overheating in about 5-10 minutes
Old 01-30-2021, 12:39 AM   #5
Elliot Naess's Avatar
Engine: 5,9 Cummins
Many compressor regulators are adjustable. Or it can be replaced with an adjustable one, or one with a higher fixed setting.
You should probably let a power tool shop or air tool shop handle it.
Old 01-30-2021, 01:06 AM   #6
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Rated Cap: 16?
I have an uncle in lucerne it’s nice up there.
Old 01-30-2021, 09:26 AM   #7
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Like ISAF says...use the pressures on the info tag on the vehicle, not the "max pressure" or "max load at xxx psi" marking on the tires. And note that some buses have different air pressure specs for front and rear axle tires.
If you need air while out and about, and you're near a truck stop, you can find high-pressure air hoses and proper inflation chucks near the semi fuel pumps. The little inflation stations out front, for the passenger cars, which take quarters often won't go above 90 psi or so. The air hoses near the semi pumps have enough pressure to air you up and they don't require quarters. And remember that the air pressure specs for your tire are for a "cold" tire. As you drive and the tire gets hot, the air expands and the pressure will increase...so you don't want to let air out of a hot tire to get to your specified pressure, because when the tire cools the pressure could be too low.
